Help; I just upgraded my forum from 1.3.4 to 1.3.5 and it seems to have killed it.
I’m using the docker install.
I tried going to /var/discourse and doing git pull and ./launcher rebuild app and it’s the same. I can see my custom header but underneath that is just white nothing.
Any suggestions on how I can get my forum back online? (I do have daily backups - though I cannot reach the backups interface).
I’m sure that when I comment out discourse-akismet and rebuild then my forum comes back.
My forum is on the stable channel (which right now means Discourse v. 1.3.5). I wonder if the HEAD version of discourse-akismet works with 1.5.x (whatever meta is running?) but not with 1.3.x.
Would be nice if there was a way to specify a particular revision of a plugin. I’m trying to find or figure out a way to do that via a github URL, but so far no luck. Maybe I’ll fork the repo, revert the last commit on my fork and use that URL instead of the official one…
There is a way, I’d just like to solve the core problem and not have to resort to that. I’m going to try and reproduce with the exact set up you have later today.
It looks like the latest commit to the tagging plugin wasn’t backwards compatible. I’ve reverted it and now if you install the latest version of tagging your site should work.
