Noticed after upgrading today, I can’t see post previews..
Nope, no such breakage on our end. This usually means your install is messed up, I hear of preview issues a lot when https is not enabled properly.
Interesting you should mention https, I just installed letsencrypt today, took me literally all day, I broke everything and had to rebuild from the ground up. ![]()
Is there a solution?
How did you do it? Was it something other than running ./discourse-setup and providing an email address for let’s encrypt?
If https is set up correctly, you should turn on the force_https site setting.
You guys are great, thanks!
You will likely need to hard refresh, possibly even restart your server.
Ill try it and get back to you asap
I was using the wrong configuration in my nginx.conf file
Thanks for your help guys! Much appreciated, keep up the good work!
