./launcher rebuild commando mislukt wanneer app.yml een lange omgevingsvariabele bevat
I’m trying to add a private key to env via the app.yml.
After I add it, it all stops working. If I remove it, it seems to all go back to normal.
The value i’m trying to add looks like this and is a line with 1755 chars
PRIVATE_KEY: “-----BEGIN PRIVATE KEY-----\n…\n…\n-----END PRIVATE KEY-----\n”
How can I fix this?
> Ensuring launcher is up to date
> Fetching origin
> remote: Enumerating objects: 7, done.
> remote: Counting objects: 100% (7/7), done.
> remote: Compressing objects: 100% (4/4), done.
> remote: Total 4 (delta 2), reused 0 (delta 0), pack-reused 0
> Unpacking objects: 100% (4/4), done.
> From gitlab.com: REPO
> 6075498..d46af48 master -> origin/master
> Updating Launcher
> Updating 6075498..d46af48
> Fast-forward
> containers/app.yml | 6 ++----
> 1 file changed, 2 insertions(+), 4 deletions(-)
> Fetching origin
> Launcher is up-to-date
> Stopping old container
> + /usr/bin/docker stop -t 60 app
> app
> cd /pups && git pull && /pups/bin/pups --stdin
> /usr/bin/docker: invalid reference format: repository name must be lowercase.
> See '/usr/bin/docker run --help'.
> cat: cids/app_bootstrap.cid: No such file or directory
> "docker rm" requires at least 1 argument.
> See 'docker rm --help'.
> Usage: docker rm [OPTIONS] CONTAINER [CONTAINER...]
> Remove one or more containers
> rm: cannot remove 'cids/app_bootstrap.cid': No such file or directory
> ** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one.
> ./discourse-doctor may help diagnose the problem.
Did you remove the line breaks? Can they be substituted with \n ?
Store the private key in a separate file and pass it in.
@Stephen an you help me that?
If I would have the file.json in the same directory as app.yml, how would the line look in app.yml?
I made 27 variables … ending in newlines… apparently if doesnt like 2 newlines in a variable, but I cannot use it like this. I need it in a specific name env variable.
Have you tried using multiline YAML instead?
https://yaml-multiline.info/
I’ve tried the | format, because i need the newlines. It gave me another error, something about a comment. I’ve resorted to using the —env-file docker_args parameter when calling the ./launcher command. It assigned something to the env variable, but i have to check if its correct.
The cert.env file created contained only one env variable, the cert.
I will come back later with news, after i check.
Yup seems to work. I will do more testing but for now i think its a good solution
