LDAP met OpenID Connect SSO met Keycloak
SantoshKM is seeking help with integrating LDAP and OpenID Connect SSO using Keycloak in a Discourse setup. While LDAP authentication for existing users from Active Directory works fine, new SSO users face a “Primary email has already been taken” error. pfaffman explains that SSO should be the sole login method and suggests migrating existing users to SSO. SantoshKM clarifies that LDAP users can still log in, but SSO users encounter a registration prompt and email activation notifications, unlike LDAP users. He asks about the fate of posts made by LDAP users and whether users can return to LDAP login in the future, highlighting a need for a seamless transition between the two authentication methods.
Dear All,
I am bit new on this.
in my currant setup, we are not using local login and have installed LDAP plug in to get authentication from Active directory and there are 50 users using.
Now due to compliance reason we have to use SSO with Keycloak.
Have setup Openid Connect with Keycloak and new user can login but existing users are getting message " Primary email has already been taken"
can any one please help me how to get this off- i want to keep LDAP plug in along with SSO ( Openid Connect) with Keycloak both active with same email address.
what wrong i am doing ???
And the existing users can’t log in but are asked to create a new account? They should be matched by email address.
If you use sso then that is the only login you can use. I think you’ll need to migrate your existing users to the SSO system.
Thank you so much, i have one query.
Existing users from LDAP login can login without any issue, only SSo users are getting creation popup.
I have 2 plugin, i) LDAP and ii) Openid Connect.
  1. i am ok to remove ldap users and ask them
    To login via SSO but, What will happen of those post which users have already posted from LDAP login ?
  2. Can they come back to LDAP login from SSO in near future ?
  3. when user coming from SSO, they are getting email notification for activation, how to avoid this ? Ldap users are not getting this and they can directly login
User from LDAP and SSO both are from same active directory.
Appreciate your quick revert.
