Links to tags not working in final post unless autocompleted
A user, robmc, reported that links to tags are not working in the final post unless autocompleted. The issue arises when manually typing a tag without the required ::tag suffix. jomaxro explained that the suffix is necessary to avoid namespace collisions with categories. codinghorror agreed that this is a big regression and suggested that tags and categories should share the same namespace. jomaxro clarified that the ::tag requirement has been in place since 2016. codinghorror disagreed with the design and mcwumbly shared this sentiment. The issue has been fixed by tgxworld with a commit to the Discourse repository.
If you add a # and select a relevant tag, the word is automatically converted to a link for the relevant tag in the Preview Pane, but this link is not appearing in the final ‘baked’ post in the forum
See here - code entered, preview pane shows bolded, working link - but not appearing in the actual topic posted (above)
(running 1.8.0 with Communiteq (formerly DiscourseHosting))
2 Me gusta
Can you repro this here or on try.discourse.org ? If it is a bug in 1.8 it won’t be fixed, because it is not security related.
This does appear to be a valid bug. To link to a tag you need ::tag at the end to avoid a namespace collision with categories. So linking to pr-welcome is #pr-welcome::tag.
With that in mind, linking to pr-welcome (#pr-welcome) works in preview but not once submitted.
I’ll note that using autocomplete when typing a tag adds ::tag automatically. This is only an issue when typing the tag “manually”.
3 Me gusta
¿Eh? ¿Qué?
pr-welcome está bien como etiqueta. También lo está pr-welcome.
Añadiendo Community Building > Praise desde el autocompletado.
Ah, ya veo, esto es un gran problema. ¡Alguien debería echarle un vistazo!
3 Me gusta
El elogio es una categoría, no tiene un “sufijo”. Solo las etiquetas requieren que se añada ::etiqueta.
Oh right my bad #faq-material::tag entered from autocomplete, and #faq-material typed.
@tgxworld I really do not agree with this design. Like users and groups, tags and categories should share the same namespace.. the #blah:tag pattern should only be required for disambiguation.
2 Me gusta
Thanks both - sorry, time differences make timely conversations awkward.
I was not aware of the requirement for the ::tag - is this new?
It does work for autocomplete, but I had written these manually as tags were bottom of the original automcomplete list and it was just as easy to type. Now I know the correct process, I can change to use autocomplete more, but as I say, I was not aware of this before
thanks for looking into it
3 Me gusta
No - it’s been required since tags became mentionable in early 2016.
2 Me gusta
Would love to see this change!
Fixed in
https://github.com/discourse/discourse/commit/3e53dbcade3c645e3cbd77610e4a5792a2c1a02e
7 Me gusta
This topic was automatically closed after 27 hours. New replies are no longer allowed.
