Logging in with security key fails when triggered by keyboard navigation
When attempting to log in to an account with a security key enabled, triggering the button using the enter key rather than clicking on it will return an invalid key error, even though I know it is valid. Once this has happened, it totally breaks and further attempts of logging in at all do not work until a refresh.
Attempting to retry it by clicking the button will return a challenge mismatch, and finally trying a totp code returns an unknown error (devtools shows that the second factor code is never actually sent in the request).
The totp error has the following stack trace
ArgumentError (`otp` should be a String)
rotp (6.2.2) lib/rotp/otp.rb:42:in `verify'
rotp (6.2.2) lib/rotp/totp.rb:46:in `block in verify'
rotp (6.2.2) lib/rotp/totp.rb:45:in `each'
rotp (6.2.2) lib/rotp/totp.rb:45:in `verify'
app/models/concerns/second_factor_manager.rb:50:in `block in authenticate_totp'
activerecord (7.0.4.3) lib/active_record/relation/delegation.rb:88:in `each'
app/models/concerns/second_factor_manager.rb:43:in `authenticate_totp'
app/models/concerns/second_factor_manager.rb:124:in `authenticate_second_factor'
app/controllers/session_controller.rb:659:in `authenticate_second_factor'
app/controllers/session_controller.rb:318:in `create'
actionpack (7.0.4.3) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.4.3) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/rendering.rb:53:in `process_action'
actionpack (7.0.4.3) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
app/controllers/application_controller.rb:414:in `block in with_resolved_locale'
i18n (1.12.0) lib/i18n.rb:322:in `with_locale'
app/controllers/application_controller.rb:414:in `with_resolved_locale'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.4.3) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.4.3) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.4.3) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.4.3) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.4.3) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.4.3) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.4.3) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.4.3) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.0.0) lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack (7.0.4.3) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.4.3) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:852:in `call'
lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
rack (2.2.6.4) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.6.4) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.6.4) lib/rack/head.rb:12:in `call'
actionpack (7.0.4.3) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:369:in `call'
rack (2.2.6.4) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.6.4) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.4.3) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/show_exceptions.rb:26:in `call'
logster (2.12.2) lib/logster/middleware/reporter.rb:43:in `call'
railties (7.0.4.3) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.4.3) lib/rails/rack/logger.rb:27:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/request_id.rb:26:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
rack (2.2.6.4) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.6.4) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.0.0) lib/mini_profiler/profiler.rb:249:in `call'
message_bus (4.3.2) lib/message_bus/rack/middleware.rb:60:in `call'
lib/middleware/request_tracker.rb:228:in `call'
railties (7.0.4.3) lib/rails/engine.rb:530:in `call'
railties (7.0.4.3) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.4.3) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.6.4) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.6.4) lib/rack/urlmap.rb:58:in `each'
rack (2.2.6.4) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Does the workaround of starting fresh and using the right key get you around the issue?
Agree entirely we should behave more gracefully here.
Refreshing fixes it, yes. But in this case it’s not a matter of using the wrong key, as I only used the key registered in icloud keychain. The prompt was just never shown to me at all.
Although I wasn’t able to trigger this with any browser other than safari.
