The 'enter' key does nothing when logging in on Android
The Android app’s login feature is experiencing an issue where the “enter” key on the mobile keyboard does nothing. ron_jeremy initially thought the app was broken, but discovered that lowering the keyboard and clicking the Discourse login button was necessary to complete the process. This issue was confirmed by codinghorror on a Nexus 5.
The problem seems to be that the keyboard is giving a “Next Field” button (right-facing arrow) instead of an “Enter” button, as noted by riking. This issue has been fixed by tgxworld in a GitHub commit.
I just downloaded the Android app and thought it was broken because I was unable to login. Then I realized that hitting the enter key at the bottom right corner of the keyboard does nothing. I had to lower the keyboard and then hit the Discourse login button to complete the process.
I am using a Nexus 6P on latest (as of today) Android Nougat.
2 curtidas
Can you screenshot the specific place you mean.
Here’s the login screen on my phone. After I type in my password I (naturally) clicked on the arrow at the bottom right corner of the keyboard expecting it to register as an ‘enter’ key. But, it does nothing. Like I said in my original post, at first I thought my password was wrong because I wasn’t being logged in.
https://goo.gl/photos/1ZbhTYKKiXuESUWk8
In order to complete the login I had to drop the keyboard out of the way to click the (now visible) login button.
https://goo.gl/photos/SwYUdtKmYUZ7ABqD9
Wow, that’s weird. The 2 images I just posted are not displaying properly in the forum (I used direct links to the images in my Google Photos).
Here they are again as links not on separate lines: https://goo.gl/photos/LMyab5PeVGHbwYvu5 and https://goo.gl/photos/vLSs14tbN6DP4cKa6.
On another note, any idea why pasting the URL on it’s own line causes the image to not display properly? Actually, I will start a new thread about the image issue.
Your images are too tall, so they are being cropped. Actually it looks like this is a quirk of Google Photos; try uploading the image directly here to compare.
If you log in via the Chrome browser directly, does enter on your mobile touch keyboard work as expected?
Here are both images uploaded to the forum:
No, it doesn’t work. Clicking the enter key does nothing. I have to drop the keyboard out of the way and then click on the Discourse “Log In” button.
More Google Photos weirdness. Here’s a direct link (posted on a separate line) to a video on my Google Photos. The video looks like it’s interpreted as an image.
https://goo.gl/photos/w1vbUN8D2xMBEjaV9
But as you can see the video plays fine if you link it this way: https://goo.gl/photos/w1vbUN8D2xMBEjaV9
Back on topic – I can confirm this on my beater Nexus 5. Enter on touch keyboard should work to log in, can you have a look Monday @tgxworld?
4 curtidas
It looks like the keyboard is giving a “Next Field” button (right facing arrow) instead of an “Enter” button.
4 curtidas
Fixed in
https://github.com/discourse/discourse/commit/e721e316990fce219a576101ba3eb7b2475b4843
4 curtidas
