Logo next to user title
Hey guys!
Is there a way to add a logo next to a users title in the forum? I want to avoid telling them to change the avatar. Thanks in advance!
You can add avatar flair based on group membership, would that help any?
Is that a plugin that needs to be installed? Would appreciate some resource :slight_smile:
Avatar flair is a native feature of Discourse, no plugin required.
Look at the settings on a group, and be sure to set that group as the users primary for it to appear.
Go to /g, click on New Group:
Go to Manage → Profile and set an icon:
Then in Manage → Membership and check “Automatically set as primary group”:
Then the icon will be displayed next to the avatar of the group members.
More info:
You’re awesome guys, thanks so much :slight_smile:
