Je viens de remarquer que les modifications du wiki ne comptent pas pour remonter un sujet dans les derniers. J’ai également remarqué que les messages du wiki ne comptent pas comme de nouveaux messages. Je souhaite que les modifications du wiki soient comptées comme de nouveaux messages. Je me demandais si quelqu’un avait des idées sur la façon de procéder ?
I’m 95% sure this isn’t true, if the wiki post is the last post in the topic (or the only post, if it is the first post, which also means it is simultaneously the first and last post) it will get bumped.
So if you want this behavior, post a wiki then close the topic so nobody can reply, only edit.
Is there any other options for making it go into latest besides closing a topic?
For example if you didn’t have the ability to close a topic (if you aren’t a leader)
At the Fairphone Forum what we usually do if the first post of a topic turns into a topic is we move the first post to a new topic and close it (don’t forget to delete the “this topic is closed” post or that one will be the last one) and then prominently link topic and wiki to each other.
We are not 100% consistent with this yet, but most topics in our #wiki view are ordered by last edit of the wiki.
