Managing multiple tags seems be tricky
A discussion about the challenges of managing multiple tags in Discourse, specifically removing tags. nesnera reported an issue with removing a tag from a post with multiple tags. jomaxro suggested updating to the latest version. After updating to v1.9.0.beta16 +69, nesnera found it easier to navigate by mouse scrolling but not by keyboard. joffreyjaffeux explained that the tag chooser is not yet using Select Kit, which will improve its behavior once implemented.
Have a post with five tags e.g. first-tag, second-tag, third-tag, fourth-tag, fifth-tag, and try to remove “second-tag”. Do I really need to remove the last few tags first?
screen_-2017-12-15
v1.9.0.beta16 +42
Hmm…I can’t repro that here on Meta. Can you try updating to latest and seeing if it’s resolved?
v1.9.0.beta16 +421 is latest, isn’t it?
Sorry for the delay. It was not latest at the time, no. You were missing two commits by @j.jaffeux which may be related. Please try updating and see if that resolves the issue.
Never mind :slight_smile:
Updated to v1.9.0.beta16 +69. It’s better now - I can navigate by mouse scrolling but not by cursor/key arrows/keyboard. It’s not very intuitive and user-friendly :frowning:
tag chooser is not using select kit yet, it’s behavior will improve once it will be done.
This topic was automatically closed after 2 days. New replies are no longer allowed.
