I’m working on an importer for answerhub and need to mark posts as solved. A couple other importers do something like this:
if topic["answer"] == '[accepted]'
post.custom_fields['is_accepted_answer'] = true
And then later call this:
def mark_topics_as_solved
puts "", "Marking topics as solved..."
PostAction.exec_sql <<-SQL
INSERT INTO topic_custom_fields (name, value, topic_id, created_at, updated_at)
SELECT 'accepted_answer_post_id', pcf.post_id, p.topic_id, p.created_at, p.created_at
FROM post_custom_fields pcf
JOIN posts p ON p.id = pcf.post_id
WHERE pcf.name = 'is_accepted_answer'
SQL
When I do that, the posts don’t show up as solved, but if I try to mark a post as solved, I get a 500 error (presumably because it’s trying to mark a solved post as solved).
Is there something that I need to do to get rails to notice that the table has been updated?
My other solution is to just do this as a post_create_action
the_topic = Topic.find(parent)
the_topic.custom_fields['accepted_answer_post_id'] = post.id
the_topic.save
Thanks, @vinothkannans.. I wondered about that too, but it seems that post.save is getting called, by the importer code. I see that stuff is in the stashers.
