Hi,
An image uploaded through pasting has a markdown tagged address :
which seems to use the shorter base62 filename as discussed here.
But, using the base62 in a direct link does not work. Should it?
https://forum.imade3d.com/uploads/default/original/1X/
The absolute image path still seems to be the old hex encoding, as this does work:
How can I reconcile the two? How does this work?
Is there any setting to switch back to using the hex encoding in the md tags?
I like to cross-post images from my discourse forum on my website, and this makes it difficult to get the cross-postable URLs.
Thanks!
