khowie
(Kate)
1
When a response is marked as a solution, does it appear at the top of a search that is relevant to it? Or does it not impact the search function?
ondrej
Hello,
You can filter a search by going to any and pressing ‘are solved’
khowie
(Kate)
3
Awesome thanks! Can you only filter as you are searching? Or as the host of a forum can I filter so that my users see the solutions?
ondrej
4
Actually you can add a filter to a category if you enable the solved plugin so your users can see all the solved and unsolved topics.
If you go to admin, plugins and press settings for solved plugin there will be this checkbox
