Does onebox support embedding links from Medium?
I’m noticing it does not currently. Is it possible?
Thanks in advance
Medium Onebox support discussion revolves around embedding links from Medium in Discourse. Brock_Busby initially reported issues with Medium links not working in onebox, but jomaxro shared a working example. Despite this, Brock_Busby confirmed the issue persists on their site, while other platforms like Facebook and Twitch work fine.
Brock_Busby stated that the issue is consistent and occurs on the latest Discourse version (v1.9.0.beta8 +34). Falco suggested checking if the server IP is blacklisted, which Brock_Busby will investigate. Meanwhile, MarcP shared a similar issue possibly caused by CloudFlare blocking access from certain servers.
Thanks in advance
Not sure what you mean. It seems to work perfectly well here…
https://medium.com/swlh/the-iphone-x-notch-is-all-about-branding-aef4f34c365b
Ok, that’s good to know. Thanks. But still odd. It isn’t working for us, but FB, Twitch, etc work fine on our site’s onebox.
Any ideas why it may not be working for us?
Is it consistently not working, for multiple, different links?
Are you on the latest Discourse version?
Yes, consistently not working.
And yes, we are on the latest version… well v1.9.0.beta8 +34 but it was doing this before this version as well.
Try to curl the same link from inside the container. We had a similar problem with another user here on Meta, and his server ip was blacklisted on the server.
I’ll try that, thanks.
That would be ironic since I was inserting an article form our own Medium blog post ![]()
In my case it looks like they are using CloudFlare - no access from my Hetzner servers ![]()
