I think we had various of these corner cases and I thought this one was fixed, but here I got it again:
I received a notification as well as an email (with the content) for a conversation I was mentioned in, that I do not have access to. Here on meta, just two hours ago:
Pretty sure, it is not. It might have been, when the mention was scheduled, but also the Email I received contains the name of a category, I do not have access to. So at least at that time, I was not able to access it anymore:
@DeanMarkTaylor mentioned you about one of your older posts, he should know what category it was in when he did that. i.e. before or after the discussion was moved.
Okay, so the email thing is weird. I do see that the mention occurred at 9:36 AM and the topic was moved at 9:48 AM, so the mention definitely occurred before the topic was moved.
Emails can’t be un-sent, and I guess depending on how one opens tabs it might not always work, but it would be nice if the “topic is private” notifications got cleared.
Yeah, so that definitely feels odd to me. It shouldn’t have included that topic for you. Definitely seems like an edge case of some sort. But at least the mention is explainable.
I mentioned @lightyear at 2:36pm whilst the topic was in the dev category.
The topic was moved by @riking from dev to Lounge (Trust Level 3 required category) at 2:48pm.
You could probably assume the minutes are the same (just the hour is different) - I’m in the UK currently.
