Microsoft_office365 enabled_setting is deprecated - what does it mean?
Hello,
recently I found a message in forum logs:
Deprecation notice: (microsoft_office365) enabled_setting is deprecated. Please define authenticator.enabled? instead (removal in Discourse 2.9.0)
At /var/www/discourse/lib/plugin/instance.rb:740:in public_send
I use office365 login. As I understand, in 2.9.0 this login method will not work if I don’t change some option. What should my next steps?
Deprecation notes are aimed at developers. This one mean that a developer of the plugin must update this method call, in the plugin source code, during the Discourse 2.9.0 development period.
Thank you for the response. What usually happens in cases like this? Does the maintainer respond to plugin notifications himself, or should I write to the thread of this plugin? Should I be worried now?
That plugin is maintained by our team. No need to worry about this.
This deprecation warning will be taken care of as part of
https://github.com/discourse/discourse-plugin-office365-auth/pull/22
