Migrate Private Messages from vBulletin5 to Discourse
Hi there,
I’ve only found this other thread on the topic: vBulletin 5 import : how to import private messages?
Which, in classic internet fashion, mention a solution but doesn’t really share :smiley:
Is there anyone that can offer some more precise pointers or a stub script? I’m not a ruby developer but have plenty of experience as software engineer. Just need some help to start :slight_smile:
This is the default import script: discourse/script/import_scripts/vbulletin5.rb at main · discourse/discourse · GitHub
Here’s the script modification I made at the time. It’s a mess though, my database was like the creature of Frankenstein, and many lines are commented out from testing stuff, it’s not meant to be used as it is:
Look at def import_pm for the part that interest you.
And don’t forget:
Good luck ! :wink:
Also I strongly suggest you that you compare the content with the official importer so you can see exactly what changed.
Thank you so much @Canapin, much appreciated
I’ve already a couple modification that I’ll have to do on the official import script. I’ll use yours just a guidance on how to add also the pvt messages import :slight_smile:
Glad to help! Could you share your own import private message method when it’s done? I’d be curious to have a look at it, and it could be merged into the official script.
I’ll start working on it from mid-december. When I’m done I’ll publish it on a git if I can keep it “generic” enough :slight_smile:
