I found system_messages.usage_tips.text_body_template is missing some blanks in front of some img tags. I downloaded the source file https://www.transifex.com/discourse/discourse-org/serverenyml/ and the file is not the same as original file. Is that a problem in the script or a Transifex bug?
1 Mi Piace
It looks like indentation is being lost after a push (tx push -s).
Your reply can be formatted using ...:
This is **bold**.
This is <b>bold</b>.
This is [b]bold[/b].
For more formatting tips...
From Transifex:
This is **bold**.
Are we sure that this is new behaviour?
3 Mi Piace
If the <img> has indentation in the old version, then it’s a new behaviour. As far as I can remember, there isn’t an indentation in the source for system_messages.usage_tips.text_body_template.
Looks like it broke between v1.6.0.beta8 and v1.6.0.beta9
1 Mi Piace
There should be indentation in the source, I can confirm a new user on meta created minutes ago, has the correct content of that PM with the indentation.
2 Mi Piace
Did you notify Transifex about this problem?
