Missing Translation in Logs for System IP Rollup
A missing translation issue was reported in the system IP rollup logs. When the system performs an automated rollup, it produces an entry with an untranslated button name [en.admin.logs.staff_actions.actions.roll_up]. Mittineague investigated the client.en.yml file and found that there is no “roll_up” under “staff_actions.actions”. However, a similar entry was found under “staff_actions.screened_ips” which might not be the correct one. riking submitted a quick fix for the issue in a pull request.
When system performs an automated rollup, it produces the following entry:
This is the full button name:
2 Curtiram
I just looked in client.en.yml
There is no “roll_up” under “staff_actions.actions”
          actions:
            delete_user: "delete user"
            change_trust_level: "change trust level"
            change_username: "change username"
            change_site_setting: "change site setting"
            change_site_customization: "change site customization"
            delete_site_customization: "delete site customization"
            suspend_user: "suspend user"
            unsuspend_user: "unsuspend user"
            grant_badge: "grant badge"
            revoke_badge: "revoke badge"
            check_email: "check email"
            delete_topic: "delete topic"
            delete_post: "delete post"
            impersonate: "impersonate"
            anonymize_user: "anonymize user"
There is one under “staff_actions.screened_ips” but doesn’t look to be the one wanted here
        screened_ips:
          title: "Screened IPs"
          description: 'IP addresses that are being watched. Use "Allow" to whitelist IP addresses.'
          delete_confirm: "Are you sure you want to remove the rule for %{ip_address}?"
          roll_up_confirm: "Are you sure you want to roll up commonly screened IP addresses into subnets?"
          rolled_up_some_subnets: "Successfully rolled up IP ban entries to these subnets: %{subnets}."
          rolled_up_no_subnet: "There was nothing to roll up."
          actions:
            block: "Block"
            do_nothing: "Allow"
            allow_admin: "Allow Admin"
          form:
            label: "New:"
            ip_address: "IP address"
            add: "Add"
            filter: "Search"
          roll_up:
            text: "Roll up"
            title: "Creates new subnet ban entries if there are at least 'min_ban_entries_for_roll_up' entries."
4 Curtiram
Submitted a quick fix: FIX: Add missing translation by riking · Pull Request #3565 · discourse/discourse · GitHub
4 Curtiram
