Mobile application does not support forum in subfolder
The discussion revolves around a mobile application’s inability to connect to a Discourse forum hosted in a subfolder (e.g., https://www.cuba-platform.com/discuss) despite HTTPS being enabled. Users, including Ivan_Rapekas, reported issues with the app failing to load the forum, while the site worked fine in browsers. codinghorror and others speculated it might be a subfolder or configuration issue, with concerns about HTTPS setup. fefrei identified weak Diffie-Hellman parameters in the server’s SSL configuration and provided guidance to improve security. The issue was resolved after updating to version 1.9.0, which added support for subfolder forums, as confirmed by Ivan_Rapekas.
I wonder to connect my forum www.example.com/discuss using Android mobile app. Appreciated to any help.
Are you sure this is a sub folder issue, because the app has other requirements. Such as your site must be https.
Not sure, that subfolder configuration is a root cause.. The website has https proxy and the forum has a setting ‘force https’ enabled (so, almost all urls are going with https). Forum is in production mode and accesible via web browsers. Users just reported that they tried Discourse mobile app…
We think this is a local config problem on your end, but we don’t have a customer site with https on a subfolder available to test. Anyone else running a site with https on a subfolder that can test?
It isn’t on latest, but https://www.sitepoint.com/community/ fails to work in the app (same error as original poster).
I believe @jomaxro said force_https wasn’t enabled there, though, for some odd reason? I don’t know how you can be on https with that not enabled.
Oh, that I can’t confirm or deny, as I can’t see that setting.
I’m not sure. Both subfolder customers have SSL enabled but not forced that I can see. Both sites predate me, however, so I’m unsure if SSL is forced elsewhere in the config.
I can say with 100% certainty, you cannot visit Sitepoint’s Discourse instance via HTTP. It will force you over to HTTPS, but I can’t tell you if that is setup via Fastly or somethng else.
Our site is CUBA.Platform
Sure, we cannot provide admin access. But I promise that force https has been enabled. In browser I press ctrl+u to ensure that all users urls come with ssl.
@Ivan_Rapekas, what is the URL to your site?
This might be some problem with your HTTPS setup.
@fefrei, https://www.cuba-platform.com/discuss
Server accepts requests via nginx https-proxy. Everything except mobile app (and some sub folder routing issues - known bugs) works fine.
Hm, looks like HTTPS is innocent here. I’m running into the same issue on iOS (even when including the trailing slash), so this indeed looks like a subfolder issue.
On a side note, you should fix your HTTPS setup, you’re using weak Diffie-Hellman parameters. See https://weakdh.org/ for details and user SSL Labs to test your site again after you made the necessary changes. For reference, here is you current rating:
Most likely, making sure that Nginx is up to date and uses the following cipher list is enough:
ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256';
@fefrei Thank you for detailed research! I passed the information to our site admins.
The topic problem resolved with 1.9.0 after update. Now Android application fully supports forums located in subfolder. Many thanks to team for the update!:slightly_smiling_face:
