Visualização móvel: o evento de clique no seletor de emojis está propagando
I’m reporting a bug with the emoji picker in the mobile view.
Consider this scenario:
  • You are using discourse on a small device. You are in a thread and want to write an answer.
  • You are opening the emoji picker. It opens up as an overlay.
  • When you are clicking the emoji you want to insert, and below your clicking location, behind the emoji picker lies a clickable element (link, button, whatever), the emoji is picked, but the click event is bubbling up and clicking on the element.
  • This leads to opening up links, clicking buttons etc. - all without intention!
To prove this is an issue, I reproduced the exact issue here in this very forum (using another thread as example):
(Notice there is a link behind the emoji I pick, and after clicking the emoji, the link is clicked and the url changes).
2 curtidas
Indeed thanks, should be fixed by FIX: ensures click on emoji in picker doesn't propagate by jjaffeux · Pull Request #7308 · discourse/discourse · GitHub
4 curtidas
