Moderator "wrench" partially covered by site header
Not sure if this is a Discourse bug, or a site theme issue, but I have seen it discussed before (https://meta.discourse.org/t/topic-admin-wrench-is-covered-by-customized-header-bar/16721).
On a Discourse I moderate the moderator wrench is partially covered by the header when the page is scrolled all the way to the top.
If works perfectly finem but it still seems to be a UI error. Scrolling the page at all will cause the wrench to be uncovered.
Issue with your site header, you will need to adjust css. @techapj can assist.
@jomaxro I just added the custom CSS to adjust Admin wrench position for StoneHearth Discourse instance.
