Modifying the history view
Is it possible to modify the history view with a theme component? I’m interested in changing the rendered output.
I was thinking about something like api.decorateCookedElement() where you can modify the cooked posts (but for the history view), but wasn’t able to figure it out. The components reviewable-histories and reviewable-post-edits also looked promising.. but hit a dead end.
What problem are you trying to solve?
I got a theme component where I’m modifying the cooked posts (specific the images). I would like to modify the “cooked” history view in exactly the same way.
Right now, when you use the theme component and look at the history, it doesn’t look like the cooked post. It looks like it would if you wouldn’t use the TC.
