Mijn forum blijft op het laadscherm staan "Kon module `virtual-dom` niet vinden"
The user Kumandan encountered an issue where their Discourse forum was stuck on a loading screen after an update, displaying the error “Could not find module virtual-dom”. The problem was traced to the Discourse Chatbot plugin, which caused issues even when disabled. pfaffman and Don suggested checking the plugin configuration and rebuilding the app. Canapin pointed out that the plugin requires PostgreSQL embedding, which may have been misconfigured. After disabling all plugins and rebuilding, the site worked again. Kumandan confirmed that rebuilding with only the Discourse Chatbot plugin disabled resolved the issue Kumandan.
For 2 years, our Discourse forum site, which we have been actively using, cannot go beyond the loading screen after an error occurred during the update last night. I was doing all updates regularly at intervals of 2-3 days.
Although I tried many of the solutions suggested in this Forum, I could not solve it. I will be grateful if anyone has any ideas about the subject.
This is discourse-doctor output file
https://forum.liwasoft.com/MTFmOWIxZjFiNzJlNDE4.txt
I also tried to log in with Safe Mode, but unfortunately it stays on a white page and does not progress.
See this in the javascript console:
loader.js:247 Uncaught Error: Could not find module `virtual-dom` imported from `discourse/global-compat`
    at loader.js:247:1
    at u (loader.js:258:1)
    at a.findDeps (loader.js:168:1)
    at u (loader.js:262:1)
    at requireModule (loader.js:24:1)
    at HTMLDocument.<anonymous> (start-app.js:4:15)
    at discourse-boot.js:20:12
    at discourse-boot.js:1:1
javascript console output :
loader.js:247
    at loader.js:247:1
Hi, do you have a solution recommendation ?
The screenshot below can help give you more insight.
Hello :wave:
Do you mean update in the admin interface? Did you try rebuild app?
cd /var/discourse
./launcher rebuild app
Yes, I always make the update from the Admin panel.
Although I tried this and other solutions in the forum, it didn’t work.
cd /var/discourse
This is ./launcher rebuild app output :
root@discourse-ubuntu-s-1vcpu-2gb-intel-fra1-01:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
Fetching origin
remote: Enumerating objects: 6, done.
remote: Counting objects: 100% (6/6), done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 6 (delta 3), reused 6 (delta 3), pack-reused 0
Unpacking objects: 100% (6/6), 1.54 KiB | 527.00 KiB/s, done.
From https://github.com/discourse/discourse_docker
 * [new branch]      allow_other_commands_to_be_passed_to_discourse_test -> origin/allow_other_commands_to_be                                                 _passed_to_discourse_test
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20230825-1850: Pulling from discourse/base
Digest: sha256:3fd7032bbeb6f322ad7138ed154c0fc6177d75ebffba44871abea86620c0c7d5
Status: Image is up to date for discourse/base:2.0.20230825-1850
docker.io/discourse/base:2.0.20230825-1850
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-09-06T10:07:52.030240 #1]  INFO -- : Reading from stdin
I, [2023-09-06T10:07:52.038045 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2023-09-06T10:07:52.092526 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-09-06T10:07:52.093096 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2023-09-06T10:07:52.099199 #1]  INFO -- :
I, [2023-09-06T10:07:52.100631 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-09-06T10:07:52.107768 #1]  INFO -- :
I, [2023-09-06T10:07:52.109046 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2023-09-06T10:07:52.115380 #1]  INFO -- :
I, [2023-09-06T10:07:52.116446 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2023-09-06T10:07:52.122815 #1]  INFO -- :
I, [2023-09-06T10:07:52.123984 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-09-06T10:07:52.130551 #1]  INFO -- :
I, [2023-09-06T10:07:52.131725 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 ||                                             exit 0 && echo postgres already running stop container ; exit 1
2023/09/06 10:07:52 socat[18] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directo                                            ry
I, [2023-09-06T10:07:52.159111 #1]  INFO -- :
I, [2023-09-06T10:07:52.159858 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-09-06T10:07:52.163910 #1]  INFO -- :
I, [2023-09-06T10:07:52.164477 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-09-06T10:07:52.168041 #1]  INFO -- :
I, [2023-09-06T10:07:52.168567 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-09-06T10:07:52.171257 #1]  INFO -- :
I, [2023-09-06T10:07:52.171907 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-09-06T10:07:52.174840 #1]  INFO -- :
I, [2023-09-06T10:07:52.181245 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2023-09-06T10:07:52.187674 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2023-09-06T10:07:52.194307 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2023-09-06T10:07:52.200997 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2023-09-06T10:07:52.202082 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-09-06T10:07:53.546969 #1]  INFO -- :
I, [2023-09-06T10:07:53.547898 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -                                            g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data                                             || exit 0
I, [2023-09-06T10:07:53.551386 #1]  INFO -- :
I, [2023-09-06T10:07:53.551913 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-09-06T10:07:53.601227 #1]  INFO -- :
I, [2023-09-06T10:07:53.602202 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-09-06T10:07:53.606172 #1]  INFO -- :
I, [2023-09-06T10:07:53.607055 #1]  INFO -- : > /root/upgrade_postgres
I, [2023-09-06T10:07:53.617450 #1]  INFO -- :
I, [2023-09-06T10:07:53.618199 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2023-09-06T10:07:53.621923 #1]  INFO -- :
I, [2023-09-06T10:07:53.624297 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_d                                            irectory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.625392 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*                                            ' in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.626158 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit                                             = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.626893 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_sh                                            ared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.627544 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /e                                            tc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.628157 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_tex                                            t_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.628774 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-09-06T10:07:53.635315 #1]  INFO -- :
I, [2023-09-06T10:07:53.636382 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segment                                            s = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.637284 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector =                                             $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.638033 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_dur                                            ation_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-09-06T10:07:53.639094 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local r                                            eplication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-09-06T10:07:53.639784 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/                                            0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-09-06T10:07:53.640348 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/                                            0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-09-06T10:07:53.640882 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:post                                            gres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-09-06T10:07:53.643802 #1]  INFO -- : > sleep 5
2023-09-06 10:07:53.757 UTC [41] LOG:  starting PostgreSQL 13.12 (Debian 13.12-1.pgdg110+1) on x86_64-pc-linux-gnu                                            , compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-09-06 10:07:53.759 UTC [41] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-09-06 10:07:53.760 UTC [41] LOG:  listening on IPv6 address "::", port 5432
2023-09-06 10:07:53.763 UTC [41] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-09-06 10:07:53.768 UTC [44] LOG:  database system was shut down at 2023-09-06 10:07:41 UTC
2023-09-06 10:07:53.781 UTC [41] LOG:  database system is ready to accept connections
I, [2023-09-06T10:07:58.651833 #1]  INFO -- :
I, [2023-09-06T10:07:58.652118 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2023-09-06 10:07:58.761 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2023-09-06 10:07:58.761 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2023-09-06T10:07:58.764702 #1]  INFO -- :
I, [2023-09-06T10:07:58.765307 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || tru                                            e
2023-09-06 10:07:58.846 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2023-09-06 10:07:58.846 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2023-09-06T10:07:58.849700 #1]  INFO -- :
I, [2023-09-06T10:07:58.850424 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on databas                                            e discourse to discourse;"' || true
I, [2023-09-06T10:07:58.911025 #1]  INFO -- : GRANT
I, [2023-09-06T10:07:58.914676 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to di                                            scourse;"'
I, [2023-09-06T10:07:58.971507 #1]  INFO -- : ALTER SCHEMA
I, [2023-09-06T10:07:58.972254 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists                                             hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2023-09-06T10:07:59.055129 #1]  INFO -- : CREATE EXTENSION
I, [2023-09-06T10:07:59.055871 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists                                             pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2023-09-06T10:07:59.129155 #1]  INFO -- : CREATE EXTENSION
I, [2023-09-06T10:07:59.129854 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists                                             vector;"'
NOTICE:  extension "vector" already exists, skipping
I, [2023-09-06T10:07:59.201973 #1]  INFO -- : CREATE EXTENSION
I, [2023-09-06T10:07:59.202707 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists                                             hstore;"'
I, [2023-09-06T10:07:59.274443 #1]  INFO -- : CREATE EXTENSION
I, [2023-09-06T10:07:59.275143 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists                                             pg_trgm;"'
I, [2023-09-06T10:07:59.347393 #1]  INFO -- : CREATE EXTENSION
I, [2023-09-06T10:07:59.348090 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists                                             vector;"'
I, [2023-09-06T10:07:59.419292 #1]  INFO -- : CREATE EXTENSION
I, [2023-09-06T10:07:59.420104 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2023-09-06T10:07:59.426697 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where                                             datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-09-06T10:07:59.522737 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: p                                            ostgres:postgres
I, [2023-09-06T10:07:59.528639 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2023-09-06T10:07:59.529342 #1]  INFO -- : > echo postgres installed!
I, [2023-09-06T10:07:59.534253 #1]  INFO -- : postgres installed!
I, [2023-09-06T10:07:59.542028 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2023-09-06T10:07:59.549287 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2023-09-06T10:07:59.556556 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2023-09-06T10:07:59.558111 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2023-09-06T10:07:59.559479 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2023-09-06T10:07:59.560725 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-09-06T10:07:59.565643 #1]  INFO -- :
I, [2023-09-06T10:07:59.566782 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.co                                            nf
I, [2023-09-06T10:07:59.567775 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2023-09-06T10:07:59.569018 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis                                            /redis.conf
I, [2023-09-06T10:07:59.570568 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc                                            /redis/redis.conf
I, [2023-09-06T10:07:59.571660 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/r                                            edis/redis.conf
I, [2023-09-06T10:07:59.572821 #1]  INFO -- : > echo redis installed
I, [2023-09-06T10:07:59.576789 #1]  INFO -- : redis installed
I, [2023-09-06T10:07:59.577721 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-09-06T10:07:59.586310 #1]  INFO -- : logfile ""
I, [2023-09-06T10:07:59.587098 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redi                                            s.conf
I, [2023-09-06T10:07:59.590330 #1]  INFO -- : > sleep 10
110:C 06 Sep 2023 10:07:59.607 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
110:C 06 Sep 2023 10:07:59.608 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=110, just started
110:C 06 Sep 2023 10:07:59.608 # Configuration loaded
110:M 06 Sep 2023 10:07:59.609 * monotonic clock: POSIX clock_gettime
110:M 06 Sep 2023 10:07:59.611 * Running mode=standalone, port=6379.
110:M 06 Sep 2023 10:07:59.611 # Server initialized
110:M 06 Sep 2023 10:07:59.612 # WARNING Memory overcommit must be enabled! Without it, a background save or repli                                            cation may fail under low memory condition. Being disabled, it can can also cause failures without low memory cond                                            ition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /                                            etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
110:M 06 Sep 2023 10:07:59.613 * Loading RDB produced by version 7.0.7
110:M 06 Sep 2023 10:07:59.613 * RDB age 20 seconds
110:M 06 Sep 2023 10:07:59.613 * RDB memory usage when created 8.58 Mb
110:M 06 Sep 2023 10:07:59.637 * Done loading RDB, keys loaded: 1872, keys expired: 2.
110:M 06 Sep 2023 10:07:59.637 * DB loaded from disk: 0.025 seconds
110:M 06 Sep 2023 10:07:59.638 * Ready to accept connections
I, [2023-09-06T10:08:09.596894 #1]  INFO -- :
I, [2023-09-06T10:08:09.597636 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-09-06T10:08:09.601840 #1]  INFO -- : thpoff is installed!
I, [2023-09-06T10:08:09.602423 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-09-06T10:08:09.670633 #1]  INFO -- :
I, [2023-09-06T10:08:09.671330 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-09-06T10:08:09.742329 #1]  INFO -- :
I, [2023-09-06T10:08:09.743092 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-09-06T10:08:09.815476 #1]  INFO -- :
I, [2023-09-06T10:08:09.816085 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-09-06T10:08:09.819688 #1]  INFO -- :
I, [2023-09-06T10:08:09.823510 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2023-09-06T10:08:09.829557 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2023-09-06T10:08:09.835437 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2023-09-06T10:08:09.840953 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2023-09-06T10:08:09.846437 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2023-09-06T10:08:09.851621 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2023-09-06T10:08:09.852116 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-09-06T10:08:09.852560 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-09-06T10:08:09.855348 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
137:C 06 Sep 2023 10:08:09.864 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
137:C 06 Sep 2023 10:08:09.864 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=137, just started
137:C 06 Sep 2023 10:08:09.864 # Configuration loaded
137:M 06 Sep 2023 10:08:09.865 * monotonic clock: POSIX clock_gettime
137:M 06 Sep 2023 10:08:09.865 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
137:M 06 Sep 2023 10:08:09.866 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33693/33693), done.
I, [2023-09-06T10:08:13.710732 #1]  INFO -- : HEAD is now at 058c8496f DEV: Convert explain-reviewable modal to component-based API (#23274)
I, [2023-09-06T10:08:13.711329 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2023-09-06T10:08:13.879285 #1]  INFO -- :
I, [2023-09-06T10:08:13.880014 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
 - [deleted]             (none)     -> origin/0-constrain
 - [deleted]             (none)     -> origin/0-sadd
 - [deleted]             (none)     -> origin/0-sticky-service
 - [deleted]             (none)     -> origin/a11y-topic-navigation
 - [deleted]             (none)     -> origin/admin-report-tab-fix
 - [deleted]             (none)     -> origin/cache-theme-fields-once
 - [deleted]             (none)     -> origin/composer-warnings-use-notice
 - [deleted]             (none)     -> origin/debug-macros-patch
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.2.3
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.5.4
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.2.1
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.4.3
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.3.2
 - [deleted]             (none)     -> origin/dev/change-custom-modal-api-reviewable-item
 - [deleted]             (none)     -> origin/dev/move-delete-user-action-to-agree-menu-part-2
 - [deleted]             (none)     -> origin/dev/no-need-to-track-status-of-deleted-user
 - [deleted]             (none)     -> origin/ember-this-fallback
 - [deleted]             (none)     -> origin/issue/admin-plugin-improvements-modernization
 - [deleted]             (none)     -> origin/loic-chat-specs-refactor
 - [deleted]             (none)     -> origin/revert-23267-ux-chat-composer-divider-fix
 - [deleted]             (none)     -> origin/upgrade-login-modal
 - [deleted]             (none)     -> origin/uploads-in-backup
   058c8496f..48951bb35  main                    -> origin/main
 * [new branch]          0-fix-category          -> origin/0-fix-category
 * [new branch]          0-tooltip               -> origin/0-tooltip
 + 560460ee8...49f177131 2fa-a11y-updates        -> origin/2fa-a11y-updates  (forced update)
   249b97ce9..f4d8ff71d  a11y-contrast           -> origin/a11y-contrast
 * [new branch]          add_support_for_uploading_a_theme_from_directory_in_system_tests -> origin/add_support_for_uploading_a_theme_from_directory_in_system_tests
 + 63cb7d4ec...678a7747d category-bullet-only    -> origin/category-bullet-only  (forced update)
 * [new branch]          category-bullet-only-generator -> origin/category-bullet-only-generator
 * [new branch]          composer-warnings-use-notice-alt -> origin/composer-warnings-use-notice-alt
 * [new branch]          create-personal-chat-notifications -> origin/create-personal-chat-notifications
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.3.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.3.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.6.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.6.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.5.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.5.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.5.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.5.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.4.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.4.0
 * [new branch]          dev-convert-grant-badge-modal-to-component-api -> origin/dev-convert-grant-badge-modal-to-component-api
 + 8c8bdc283...d379b4a0f dev/convert-change-post-notice-to-glimmer-dmodal -> origin/dev/convert-change-post-notice-to-glimmer-dmodal  (forced update)
 * [new branch]          dev/topic-list-item-plugin-outlet -> origin/dev/topic-list-item-plugin-outlet
   a4bb515c3..d9dfbda61  discovery-named-outlets -> origin/discovery-named-outlets
   5cee6ec88..800592d0a  feature/show-status-on-mentions-when-user-havent-used-autocomplete -> origin/feature/show-status-on-mentions-when-user-havent-used-autocomplete
 + 78f0fe6fb...656e045ba fix/do-not-consider-codeblocks-when-parsing-mentions -> origin/fix/do-not-consider-codeblocks-when-parsing-mentions  (forced update)
 * [new branch]          fix/do-not-consider-codeblocks-when-parsing-mentions-alt -> origin/fix/do-not-consider-codeblocks-when-parsing-mentions-alt
 + 3ce70aa3f...b7214faff generic-import-latest   -> origin/generic-import-latest  (forced update)
 + fea7a44a1...38c443170 loic-migrate-chat-message-creator-to-a-service -> origin/loic-migrate-chat-message-creator-to-a-service  (forced update)
 * [new branch]          noised                  -> origin/noised
 * [new branch]          psql-output-tests       -> origin/psql-output-tests
 * [new branch]          redo-post-focus-setting -> origin/redo-post-focus-setting
 * [new branch]          rotate-token-on-ip-change -> origin/rotate-token-on-ip-change
   f81ed652f..28b632ace  stable                  -> origin/stable
 * [new branch]          test-mentions-duplicates -> origin/test-mentions-duplicates
   058c8496f..ede73f923  tests-passed            -> origin/tests-passed
 * [new branch]          theme-qunit-production  -> origin/theme-qunit-production
 * [new branch]          topic-noindex           -> origin/topic-noindex
 * [new branch]          tweak-feature-items     -> origin/tweak-feature-items
 * [new branch]          update-login-modal-mark -> origin/update-login-modal-mark
 * [new branch]          wip-close-on-click-outside-search -> origin/wip-close-on-click-outside-search
I, [2023-09-06T10:08:14.866942 #1]  INFO -- :
I, [2023-09-06T10:08:14.867410 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2023-09-06T10:08:20.116376 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2023-09-06T10:08:20.117056 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2023-09-06T10:08:20.130888 #1]  INFO -- :
I, [2023-09-06T10:08:20.131413 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2023-09-06T10:08:20.135769 #1]  INFO -- :
I, [2023-09-06T10:08:20.136271 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-09-06T10:08:20.139477 #1]  INFO -- :
I, [2023-09-06T10:08:20.139876 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-09-06T10:08:20.142928 #1]  INFO -- :
I, [2023-09-06T10:08:20.143288 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-09-06T10:08:20.146295 #1]  INFO -- :
I, [2023-09-06T10:08:20.146649 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-09-06T10:08:20.150200 #1]  INFO -- :
I, [2023-09-06T10:08:20.150609 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2023-09-06T10:08:20.153841 #1]  INFO -- :
I, [2023-09-06T10:08:20.154213 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2023-09-06T10:08:20.158930 #1]  INFO -- :
I, [2023-09-06T10:08:20.159326 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2023-09-06T10:08:20.164062 #1]  INFO -- :
I, [2023-09-06T10:08:20.164454 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2023-09-06T10:08:20.168980 #1]  INFO -- :
I, [2023-09-06T10:08:20.169378 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2023-09-06T10:08:20.173612 #1]  INFO -- :
I, [2023-09-06T10:08:20.173965 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2023-09-06T10:08:20.179314 #1]  INFO -- :
I, [2023-09-06T10:08:20.179713 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2023-09-06T10:08:20.184363 #1]  INFO -- :
I, [2023-09-06T10:08:20.184801 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-09-06T10:08:20.359596 #1]  INFO -- :
I, [2023-09-06T10:08:20.360164 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-09-06T10:08:20.363160 #1]  INFO -- :
I, [2023-09-06T10:08:20.363738 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2023-09-06T10:08:20.364556 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2023-09-06T10:08:21.440154 #1]  INFO -- :
I, [2023-09-06T10:08:21.440706 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2023-09-06T10:08:22.505481 #1]  INFO -- :
I, [2023-09-06T10:08:22.506004 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-whos-online.git
Cloning into 'discourse-whos-online'...
I, [2023-09-06T10:08:23.085292 #1]  INFO -- :
I, [2023-09-06T10:08:23.085870 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-bbcode-color.git
Cloning into 'discourse-bbcode-color'...
I, [2023-09-06T10:08:23.626593 #1]  INFO -- :
I, [2023-09-06T10:08:23.627211 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-apple-auth.git
Cloning into 'discourse-apple-auth'...
I, [2023-09-06T10:08:24.184884 #1]  INFO -- :
I, [2023-09-06T10:08:24.185553 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-user-notes.git
Cloning into 'discourse-user-notes'...
I, [2023-09-06T10:08:25.650356 #1]  INFO -- :
I, [2023-09-06T10:08:25.651013 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/paviliondev/discourse-locations.git
Cloning into 'discourse-locations'...
I, [2023-09-06T10:08:26.431109 #1]  INFO -- :
I, [2023-09-06T10:08:26.431640 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/merefield/discourse-chatbot.git
Cloning into 'discourse-chatbot'...
I, [2023-09-06T10:08:26.957464 #1]  INFO -- :
I, [2023-09-06T10:08:26.957965 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-docs.git
Cloning into 'discourse-docs'...
I, [2023-09-06T10:08:27.825042 #1]  INFO -- :
I, [2023-09-06T10:08:27.825623 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-ai.git
Cloning into 'discourse-ai'...
I, [2023-09-06T10:08:31.474693 #1]  INFO -- :
I, [2023-09-06T10:08:31.475573 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-09-06T10:08:31.484905 #1]  INFO -- :
I, [2023-09-06T10:08:31.486731 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2023-09-06T10:08:31.494926 #1]  INFO -- :
I, [2023-09-06T10:08:31.498750 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2023-09-06T10:08:31.507708 #1]  INFO -- :
I, [2023-09-06T10:08:31.509398 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2023-09-06T10:08:31.509848 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2023-09-06T10:08:31.510162 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2023-09-06T10:08:31.510949 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2023-09-06T10:08:31.511710 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2023-09-06T10:08:31.512283 #1]  INFO -- : > echo "done configuring web"
I, [2023-09-06T10:08:31.520194 #1]  INFO -- : done configuring web
I, [2023-09-06T10:08:31.522801 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2023-09-06T10:08:32.236827 #1]  INFO -- : Successfully installed bundler-2.4.13
1 gem installed
I, [2023-09-06T10:08:32.237512 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2023-09-06T10:08:35.536295 #1]  INFO -- :
I, [2023-09-06T10:08:35.536960 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
  rm -rf app/assets/javascripts/node_modules
fi
I, [2023-09-06T10:08:35.539666 #1]  INFO -- :
I, [2023-09-06T10:08:35.540029 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning "workspace-aggregator-88207ab1-6c66-4e5a-a896-759375bd53fe > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-88207ab1-6c66-4e5a-a896-759375bd53fe > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-88207ab1-6c66-4e5a-a896-759375bd53fe > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-88207ab1-6c66-4e5a-a896-759375bd53fe > discourse-plugins > ember-this-fallback@0.3.1" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-88207ab1-6c66-4e5a-a896-759375bd53fe > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
I, [2023-09-06T10:09:36.204401 #1]  INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
success Already up-to-date.
$ yarn --cwd app/assets/javascripts $(node -e 'const argv = JSON.parse(process.env.npm_config_argv).original; const passthrough = [`--frozen-lockfile`, `-s`].filter(arg => argv.includes(arg)); console.log(passthrough.join(` `));')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
$ patch-package
patch-package 8.0.0
Applying patches...
@ember/jquery@2.0.0 ✔
babel-plugin-debug-macros@0.3.4 ✔
ember-source@3.28.12 ✔
ember-this-fallback@0.3.1 (1 initial) ✔
ember-this-fallback@0.3.1 (2 themes) ✔
virtual-dom@2.1.1 ✔
Done in 54.84s.
Done in 55.95s.
yarn cache v1.22.19
success Cleared cache.
Done in 4.14s.
I, [2023-09-06T10:09:36.209010 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local deployment true'
I, [2023-09-06T10:09:36.532608 #1]  INFO -- :
I, [2023-09-06T10:09:36.533145 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local without "development test"'
I, [2023-09-06T10:09:36.707501 #1]  INFO -- : You are replacing the current local value of without, which is currently "test:development"
I, [2023-09-06T10:09:36.708100 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4'
I, [2023-09-06T10:09:56.618430 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/.........
Using rake 13.0.6
Using minitest 5.19.0
Using concurrent-ruby 1.2.2
Using racc 1.7.1
Using builder 3.2.4
Using rack 2.2.8
Using mini_mime 1.1.5
Using date 3.3.3
Using crass 1.0.6
Using public_suffix 5.0.3
Using aws-eventstream 1.2.0
Using aws-partitions 1.583.0
Using erubi 1.12.0
Using jmespath 1.6.2
Using bundler 2.4.13
Using byebug 11.1.3
Using cbor 0.5.9.6
Using cgi 0.3.6
Using chunky_png 1.4.0
Using coderay 1.1.3
Using colored2 4.0.0
Using connection_pool 2.4.1
Using openssl 3.1.0
Using cppjieba_rb 0.4.2
Using msgpack 1.7.2
Using method_source 1.0.0
Using timeout 0.4.0
Using thor 1.2.2
Using zeitwerk 2.6.11
Using tilt 2.2.0
Using diffy 3.4.2
Using digest 3.1.1
Using discourse-fonts 0.0.9
Using email_reply_trimmer 0.1.13
Using excon 0.102.0
Fetching google-protobuf 3.24.2 (x86_64-linux)
Using exifr 1.4.0
Using faraday-net_http 3.0.2
Using ruby2_keywords 0.0.5
Using fast_blank 1.0.1
Using fast_xs 0.8.0
Using fastimage 2.2.7
Using ffi 1.15.5
Using fspath 3.1.2
Using gc_tracer 1.5.1
Using guess_html_encoding 0.0.11
Using hana 1.3.7
Using hashie 5.0.0
Using highline 2.1.0
Using hkdf 1.0.0
Using htmlentities 4.3.4
Using http_accept_language 2.1.1
Using in_threads 1.6.0
Using progress 3.6.0
Using json 2.6.3
Using regexp_parser 2.8.1
Using unf_ext 0.0.8.2
Using jwt 2.7.1
Using execjs 2.8.1
Using kgio 2.11.4
Using libv8-node 18.16.0.0 (x86_64-linux)
Using logstash-event 1.2.02
Using logster 2.12.2
Using lru_redux 1.1.0
Using lz4-ruby 0.3.3
Using maxminddb 0.1.22
Using memory_profiler 1.0.1
Using redis 4.8.1
Using mini_sql 1.5.0
Using multi_json 1.15.0
Using multi_xml 0.6.0
Using mustache 1.1.1
Using uri 0.12.2
Using nio4r 2.5.9
Using version_gem 1.1.3
Fetching oj 3.16.1
Using image_size 3.3.0
Using optimist 3.1.0
Using pg 1.4.6
Using raindrops 0.20.1
Using rchardet 1.8.0
Using rexml 3.2.6
Using rinku 2.0.6
Fetching rotp 6.3.0
Using rqrcode_core 1.2.0
Using rubyzip 2.3.2
Using sshkey 3.0.0
Using stackprof 0.2.25
Using i18n 1.14.1
Using tzinfo 2.0.6
Using nokogiri 1.15.4 (x86_64-linux)
Using rack-test 2.1.0
Using addressable 2.8.5
Using aws-sigv4 1.5.0
Using bootsnap 1.16.0
Using openssl-signature_algorithm 1.3.0
Using sprockets 3.7.2 from https://github.com/rails/sprockets (at 3.x@f4d3dae)
Installing rotp 6.3.0
Using request_store 1.5.1
Using message_bus 4.3.8
Using pry 0.14.2
Using rack-mini-profiler 3.1.1
Using rack-protection 3.1.0
Using net-protocol 0.2.1
Using faraday 2.7.10
Using unf 0.1.4
Using mini_suffix 0.3.3
Using omniauth 1.9.2
Using activesupport 7.0.7
Using loofah 2.21.3
Using aws-sdk-core 3.130.2
Using cose 1.3.0
Fetching css_parser 1.16.0
Installing oj 3.16.1 with native extensions
Installing css_parser 1.16.0
Using image_optim 0.31.3
Using logstash-logger 0.26.1
Using mini_racer 0.8.0
Using sidekiq 6.5.9
Using net-http 0.3.2
Using oauth-tty 1.0.5
Using snaky_hash 2.0.1
Using puma 6.3.1
Using rbtrace 0.4.14
Using redis-namespace 1.11.0
Using rqrcode 2.2.0
Using rss 0.3.0
Using ruby-readability 0.7.0
Using sanitize 6.0.2
Using tzinfo-data 1.2023.3
Using uglifier 4.2.0
Using unicorn 6.1.0
Using web-push 3.0.0
Using rails-dom-testing 2.2.0
Fetching globalid 1.2.1
Using rails-html-sanitizer 1.6.0
Installing google-protobuf 3.24.2 (x86_64-linux)
Using net-imap 0.3.7
Using net-pop 0.1.2
Using net-smtp 0.3.3
Using activemodel 7.0.7
Using aws-sdk-kms 1.56.0
Using aws-sdk-sns 1.53.0
Using faraday-retry 2.2.0
Using simpleidn 0.2.1
Using oauth2 1.4.11
Using pry-byebug 3.10.1
Using pry-rails 0.3.9
Using mini_scheduler 0.16.0
Using rtlcss 0.2.1
Using oauth 1.1.0
Using actionview 7.0.7
Using mail 2.8.1
Using active_model_serializers 0.8.4
Using activerecord 7.0.7
Using aws-sdk-s3 1.114.0
Using json_schemer 2.0.0
Using omniauth-oauth2 1.7.3
Using omniauth-oauth 1.2.0
Installing globalid 1.2.1
Using actionpack 7.0.7
Using actionview_precompiler 0.3.0
Using discourse-seed-fu 2.3.12
Using omniauth-facebook 9.0.0
Using omniauth-github 1.4.0
Using omniauth-google-oauth2 0.8.2
Using omniauth-twitter 1.4.0
Using railties 7.0.7
Using sprockets-rails 3.4.2
Using activejob 7.0.7
Using lograge 0.13.0
Using rails_failover 2.0.1
Using rails_multisite 5.0.0
Using actionmailer 7.0.7
Using sass-embedded 1.66.1 (x86_64-linux-gnu)
Using dartsass-ruby 3.0.1
Using dartsass-sprockets 3.0.0
Bundle complete! 136 Gemfile dependencies, 172 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
I, [2023-09-06T10:09:56.618989 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2023-09-06T10:10:00.693390 #1]  INFO -- : discourse-ai is already at latest compatible version
discourse-apple-auth is already at latest compatible version
discourse-bbcode-color is already at latest compatible version
discourse-chatbot is already at latest compatible version
discourse-docs is already at latest compatible version
discourse-locations is already at latest compatible version
discourse-solved is already at latest compatible version
discourse-user-notes is already at latest compatible version
discourse-whos-online is already at latest compatible version
docker_manager is already at latest compatible version
I, [2023-09-06T10:10:00.694450 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
2023-09-06 10:10:14.940 UTC [841] discourse@discourse ERROR:  could not open extension control file "/usr/share/postgresql/13/extension/embedding.control": No such file or directory
2023-09-06 10:10:14.940 UTC [841] discourse@discourse STATEMENT:  CREATE EXTENSION IF NOT EXISTS "embedding"
----------------------------DISCOURSE CHATBOT ERROR----------------------------------
 Discourse Chatbot now requires the embedding extension on the PostgreSQL database.
                  See required changes to `app.yml` described at:
              https://github.com/merefield/discourse-chatbot/pull/33
            Alternatively, you can remove Discourse Chatbot to rebuild.
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::UndefinedFile: ERROR:  could not open extension control file "/usr/share/postgresql/13/extension/embedding.control": No such file or directory
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.1.1/lib/patches/db/pg.rb:69:in `exec_params'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql_adapter.rb:768:in `block (2 levels) in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/dependencies/interlock.rb:41:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql_adapter.rb:767:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract_adapter.rb:752:in `block in log'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract_adapter.rb:743:in `log'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql_adapter.rb:766:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql_adapter.rb:745:in `execute_and_clear'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in `exec_query'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql_adapter.rb:434:in `enable_extension'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:932:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:900:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:900:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:921:in `method_missing'
/var/www/discourse/plugins/discourse-chatbot/db/migrate/20230820010101_enable_embedding_extension.rb:6:in `change'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:870:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:854:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:853:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/connection_pool.rb:215:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:852:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1046:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1360:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/database_statements.rb:316:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/transactions.rb:209:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1411:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1359:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1432:in `block in with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1447:in `with_advisory_lock_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1428:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1117:in `up'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1092:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/tasks/database_tasks.rb:262:in `migrate'
/var/www/discourse/lib/tasks/db.rake:250:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:225:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::UndefinedFile: ERROR:  could not open extension control file "/usr/share/postgresql/13/extension/embedding.control": No such file or directory
Caused by:
Tasks: TOP => db:migrate
I, [2023-09-06T10:10:14.982239 #1]  INFO -- : gem install tokenizers -v 0.3.3 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed tokenizers-0.3.3-x86_64-linux
1 gem installed
gem install tiktoken_ruby -v 0.0.5 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed tiktoken_ruby-0.0.5-x86_64-linux
1 gem installed
gem install multipart-post -v 2.3.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed multipart-post-2.3.0
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed faraday-multipart-1.0.4
1 gem installed
gem install ruby-openai -v 4.2.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openai-4.2.0
1 gem installed
gem install google_search_results -v 2.2.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed google_search_results-2.2.0
1 gem installed
gem install wikipedia-client -v 1.17.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed wikipedia-client-1.17.0
1 gem installed
gem install childprocess -v 4.1.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed childprocess-4.1.0
1 gem installed
gem install safe_ruby -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed safe_ruby-1.0.4
1 gem installed
gem install geocoder -v 1.4.4 -i /var/www/discourse/plugins/discourse-locations/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed geocoder-1.4.4
1 gem installed
Compiled js-processor: tmp/js-processor.js
== 20230820010101 EnableEmbeddingExtension: migrating =========================
-- enable_extension(:embedding)
I, [2023-09-06T10:10:14.983047 #1]  INFO -- : Terminating async processes
I, [2023-09-06T10:10:14.983220 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
2023-09-06 10:10:14.983 UTC [41] LOG:  received fast shutdown request
I, [2023-09-06T10:10:14.983664 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 110
110:signal-handler (1693995014) Received SIGTERM scheduling shutdown...
2023-09-06 10:10:14.992 UTC [41] LOG:  aborting any active transactions
2023-09-06 10:10:15.000 UTC [41] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
2023-09-06 10:10:15.000 UTC [45] LOG:  shutting down
2023-09-06 10:10:15.024 UTC [41] LOG:  database system is shut down
110:M 06 Sep 2023 10:10:15.035 # User requested shutdown...
110:M 06 Sep 2023 10:10:15.035 * Saving the final RDB snapshot before exiting.
110:M 06 Sep 2023 10:10:15.066 * DB saved on disk
110:M 06 Sep 2023 10:10:15.066 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 762 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
There have been (rare? unique?) case when a plugin would cause an error even while disabled. Did you try to rebuild without any plugin in app.yml?
Spending hours trying to pinpoint an issue is often frustrating, and re-creating the server, or trying to restore a backup on a temporary server to see if it works is sometimes faster, even if we don’t know where the issue originates from. :confused:
edit:
Did you try this?
I have now disabled all plugins and will try the rebuild again. I will post the result here.
Yeah, the Discourse Chatbot plugin… I remember I saw the similar issue here :slightly_smiling_face:
I rebuilt it by disabling all plugins and everything seems fine now. As you suggested, I will now rebuild again by disabling only the discource-chatbot plugin.
Thank you for your concern. This solved my problem and now everything is fine :ok_hand:
