Hi
Need your advice on whether should I upgrade my digital ocean instance
currenly running on 1 cpu 2gb ram and 50gb storage instance
I am thinking of upgrading to 4gb ram
current site traffic - 100K monthly
Thanks
Hi
Thanks
upgraded to 4gb
Here is the stats
total used free shared buff/cache available
Mem: 3.8Gi 1.3Gi 160Mi 388Mi 2.3Gi 1.8Gi
Swap: 2.0Gi 2.0Mi 2.0Gi
You should run discourse-setup and it will update the memory usage in the app.yml. It will give you a chance to type control-c before it asks all of the configuration questions. Then you can do a rebuild.
Thanks for the reply
Should I stick with 4gb
Is it necessary to run this setup things
It’s probably not necessary to have 4GB for your size community, though you might benefit from extra swap.
If you resized the RAM and not the disk you can resize back to 2GB.
Thanks for prompt reply sir
yeah only resized cpu and ram not disk
Do I need to run discourse-setup after resizing ??
If you resize the memory, then you should run discourse-setup to adjust the memory settings or read the comments in app.yml and do it by hand.
