New badge, badge icon not showing on badges page
EricGT created a new badge titled ‘Useful Prolog Reference’ but noticed its icon was not displaying on the badges page. After reviewing settings and comparing HTML with working badges, he suspected the issue was with the Font Awesome icon name used — initially far-external-link-alt. ondrej suggested using fa-external-link-alt instead, noting that far refers to a different icon style. EricGT tested the suggestion but saw no change. He then tried fa-certificate, which worked 6, confirming the issue was icon-related. Eventually, he confirmed fa-external-link-alt worked correctly 7, while far-external-link-alt was indeed wrong. He shared a step-by-step guide to identifying the correct HTML for the Icon field: visit Font Awesome’s icon library, select the desired icon, and copy the HTML shown on hover. ondrej confirmed this was his original suggestion and expressed satisfaction at helping. The issue was resolved by using the correct Font Awesome class name — fa-external-link-alt — rather than far-external-link-alt.
I made a new badge, then went to the badges page via the hamburger to ensure it displayed correctly.
Everything displays as expected so far, but Useful Prolog Reference badge incon is missing from the image.
I looked at other badges as an example but see nothing that I believe to be incorrect.
Did learn to use HTML anchors instead of Markdown links.
Current settings:
Name: Useful Prolog Reference
Icon:far-external-link-alt
Image:
Badge Type: Bronze
Group: Other
Description: Link added to Useful Prolog References
Long Description:
Allow badge to be used as a tile:
Can be granted multiple times: Checked
Show badge on the public badges page: Checked
Show post granting badge on badge page:
Enable badge: Checked
Font Awesome: external-link-alt
Also compared the HTML
<div class="badge-contents">
  <div class="badge-icon badge-type-silver">
    <a href="/badges/103/great-contributor"><svg class="fa d-icon d-icon-certificate svg-icon svg-string" xmlns="http://www.w3.org/2000/svg"><use xlink:href="#certificate"></use></svg></a>
  </div>
  <div class="badge-info">
    <div class="badge-info-item">
      <h3><a href="/badges/103/great-contributor" class="badge-link">Great contributor</a></h3>
      <div class="badge-summary">contributed 25 accepted pull requests</div>
    </div>
  </div>
</div>
  <div class="badge-icon badge-type-bronze">
    <a href="/badges/108/useful-prolog-reference"><svg class="fa d-icon d-icon-far-external-link-alt svg-icon svg-string" xmlns="http://www.w3.org/2000/svg"><use xlink:href="#far-external-link-alt"></use></svg></a>
  </div>
      <h3><a href="/badges/108/useful-prolog-reference" class="badge-link">Useful Prolog Reference</a></h3>
      <div class="badge-summary">Useful Prolog References</div>
    </div>
  </div>
</div>
Nothing at first glance looks wrong.
Any ideas on how to fix?
Font awesome 5 it is:
fa-external-link-alt :check_mark:
Not… Unless you want the different icon design (correct me if I’m wrong)
fas
far
fad
fal
used: fa external-link-alt
No change. Icon not appearing.
I will try another Awesome Font to see what happens.
OK, sure thing. Let us know what happens
I can see the bronze.
Using: fa-certificate works
It was copied from Contributor so you are on the right path.
fa-external-link-alt works.
far-external-link-alt was wrong.
Awesome.
How to identify correct HTML to use for Icon field.
  1. Go to Font Awesome
  2. Click Icons
  3. Find Icon.
  4. Click on Icon, e.g. external-link-alt
  5. Mouse over HTML
So in my case, the correct HMTL is fa-external-link-alt.
Just what I originally thought :blush: happy to help!
