New badges shouldn't be on by default
I’m not a fan of new badges being turned on by default.
We don’t use most of the native Discourse badges so I have them turned off, but there was an awkward situation just now when someone received this:
I knew nothing about it and his ‘um, wow, thanks’ response was a bit awkward.
I think it’s an awesome initiative and will go down well in lots of communities, but it’s not something that we’ll use and I don’t think it should be enabled by default – at least not without notifying the CM.
7 Curtiram
Discourse changes all the time. I like to think I keep abreast of things by spending a lot of time reading here. But I understand that most don’t have that luxury.
At one time I considered trying to write a plugin that compared an existing site_settings.yml against the newer file, but it’s still on my “maybe someday” todo list.
Do you think something like that would be adequate to prevent most serious gotchas?
i.e. These Settings are new - be aware!
1 Curtiu
It would be helpful for me, yes.
I remember having a convo with someone about this a while back. I’d love it if Discourse had a What’s New / News widget on Dashboard like WP does.
3 Curtiram
I think the easiest to implement would be a link to “commits since your version”.
But I don’t see that as being the most user friendly. Kind of like sending a newbie to a W3C RFC. Everything needed is there, but can it be digested?
I guess we could petition the Discourse team to use descriptive commit tags so they could be filtered.
But I’m thinking changes in the site_settings.yml file would catch most things that would be important to forum users.
2 Curtiram
That already exists
And on the upgrade page
However, if you are hosted by Discourse (and I believe @hawk is), they sort of handle upgrading you… so you still might not get a chance to see what changed.
Out of curiosity @hawk, do you have all badges disabled or just a select number of them? As I know there is a global setting for ALL badges, setting is enable badges
4 Curtiram
Hmm if badges were disabled globally this is a bug. But I don’t think you disabled badges globally? You should disable badges globally if you don’t want badges.
Otherwise this is very much by design.
I think there is merit for a badge system is on but no stock badges are enabled by default, mode, but it is a rather rare use case
3 Curtiram
My personal preference would be that new badges (and other such changes) be preffed off by default, but that when an admin/leader logs in after the update, they have the option to enable them.
As an alternative, could it perhaps be that the preferences become available a week or so before the functionality (with a “what’s changing” notice), so that admins have the opportunity to pre-emptively disable them? I’d be happy if this was a way to set preferences by typing in a key (like Firefox’s about:config), and these were communicated via email (or announcement here) ahead of the release.
Would there be merit in something like this?
4 Curtiram
In that scenario, do users ever advance through trust levels automatically? I’m curious if the trust level badge contains the logic for advancing, or if the badge merely triggers on some other test succeeding.
In any case, I think defaulting to badges off is not such a great idea, but I can see merit in a setting for the default badge status:
Badges default to: [ enabled | disabled ]
And then a list of all the badges with current settings:
Nice Post: [ explicit enabled | explicit disabled | site default ]
Great Post: [ explicit enabled | explicit disabled | site default ]
3 Curtiram
I’m with @HAWK on this one. I’d love to see a better (more interactive) system for badges that are added. Two of my sites are closed, log in only environments, with one using SSO. As such, we’ve disabled a number of badges that are unobtainable in this setup, like shares and invites. One has no reply-by-email, so the email badge is disabled.
The most recent badge may be an extreme example (first badge to send a PM), released near end of month so it was awarded quickly - but it caught me by surprise too when I saw the PM in email logs. Some type of “a new badge has been added, check it out here” on the admin dashboard would likely be enough.
3 Curtiram
Eu também passo muito tempo lendo aqui, mas de alguma forma acabo perdendo alguns tópicos realmente cruciais. Esse novo recurso também me pegou de surpresa, e a primeira vez que soube dele foi neste tópico. Obrigado @HAWK por chamar nossa atenção! Agora estou explorando-o com minha equipe de moderadores para decidir se mantemos a ativação ou não.
Talvez a equipe do Discourse pudesse tentar ser um pouco mais vigilante ao notificar todos nós (e especialmente seus clientes pagantes) sobre novos recursos que serão “impostos” às nossas comunidades e que talvez precisem ser desativados.
Dito isso, sou profundamente grato à equipe do Discourse pelo trabalho contínuo e diligente de desenvolver e evoluir este software incrível, e estou realmente satisfeito com ele, bem como com a velocidade e o escopo das melhorias. Não tenho nenhuma reclamação sobre a direção tomada e confio plenamente no Discourse, ficando impressionado todos os dias com o que está acontecendo com o software.
Além disso, não sou um cliente pagante, então estou muito disposto a aceitar a forma como as mudanças aparecem por meio de um fluxo constante de commits no Git e de que, frequentemente, uma única reconstrução do meu site gera uma série de reconstruções nos próximos dias, à medida que novos recursos são ajustados e bugs são corrigidos. É divertido (de uma forma parecida com uma caça ao ovo de Páscoa) procurar por mudanças e novos recursos, além de relatar bugs e vê-los corrigidos rapidamente. Posso contar nas mãos, ou até mesmo com poucos dedos, o número de vezes que tive uma surpresa desagradável após uma atualização. Mesmo assim, não foi um grande problema e foi resolvido rapidamente. Sem nenhuma reclamação da minha comunidade.
Ficaria triste se o ritmo e a criatividade das melhorias diminuíssem porque a equipe tivesse que questionar cada novo recurso e gastar mais tempo olhando para trás e se preocupando excessivamente com o impacto nas instalações existentes.
Acho que, para mim, a solução será monitorar a categoria Contribute > Feature, para que eu seja notificado de cada novo post nessa categoria, mesmo que isso signifique receber algumas notificações extras sobre solicitações de recursos que não preciso ver.
5 Curtiram
We have all native badges disabled but use custom badges.[quote=“codinghorror, post:6, topic:61371”]
[/quote]
I definitely do want badges. :slight_smile: But I want to be able to choose which ones, and I don’t want new ones that I don’t know about to be activated by default.
3 Curtiram
This is such a rare use case though. Can’t say when we would get to that.
It’s a big change to make new badges not activated by default?
It’s not on our roadmap for the forseeable future, no.
/me does the PR-welcome dance, with full ruffles and flourishes
4 Curtiram
Ok, fair enough.
Is there an easy way to know when new badges will be added?
Actually my real issue here isn’t so much the badges but the fact that users are receiving messages from me that I wasn’t aware were being sent.
5 Curtiram
What are the criteria that kick this message off?
You can learn everything there is to know about the new feature that prompted this topic over here:
4 Curtiram
Isso, na verdade, está se tornando muitas notificações desnecessárias para mim, então vou desativar o acompanhamento de Contribute > Feature novamente.
De forma alguma desacelere o ritmo de desenvolvimento, mas, se possível, tente encontrar maneiras de comunicar de forma oficial sobre os recursos que estão sendo realmente implementados e que aparecerão na branch tests-passed.
3 Curtiram
