הגרסה החדשה ביותר של Discourse שוברת את ה-rebuild, ה-Redis Port כבר בשימוש
OS: Ubuntu 20.04
Server: vServer 4 Core, 16 GB
Disk: SSD 160GB
I recently upgraded to the newest Discourse Version. Now Im running into the Problem, that Discourse Reports Port 6379 is in use and so the Container can not be build:
When I check for all Ports in use, that Port is free
Something on the Discourse Check fails to recognize, that the port is free.
In Docker I can see, that only the Discourse Container started and everything else fails:
This problem really turned into a Paradox.
Discourse starts the redis-server pid in Docker and then crashes, because it started the process already:
I have a main Redis Installation on the Host running, but that one is on Port 6800, so it shouldn’t interferre.
It clearly looks, like the Check fails on itself, because Redis Starts itself succesfull and then reports failed, adress in use:
Can you please share your app.yml file?
Yes sure, thanks for looking at it :smiley:. Here is my app.yml:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "12080:80"   # http
  - "12443:443" # https
params:
  db_shared_buffers: "4096MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 8
  DISCOURSE_HOSTNAME: discourse.forum
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'developer@email'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_ADDRESS: mailserver
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: email@email
  DISCOURSE_SMTP_PASSWORD: "****"
  #DISCOURSE_SMTP_AUTHENTICATION: plain
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/angusmcleod/discourse-question-answer.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-voting.git
          - git clone https://github.com/gdpelican/retort.git
          - git clone https://github.com/davidtaylorhq/discourse-whos-online.git
          - git clone https://github.com/vinkas0/discourse-navigation.git
          - git clone https://github.com/discourse/discourse-spoiler-alert.git
          - git clone https://github.com/iunctis/discourse-formatting-toolbar.git
          - git clone https://github.com/discourse/discourse-tooltips.git
          - git clone https://github.com/gdpelican/babble.git
          - git clone https://github.com/paviliondev/discourse-quick-messages.git
          - git clone https://github.com/worldismine/PM-Scanner.git
          - git clone https://github.com/paviliondev/discourse-ratings.git
          - git clone https://github.com/discourse/discourse-calendar.git
          - git clone https://github.com/jannolii/discourse-topic-trade-buttons.git
run:
  ##- exec: rails r "SiteSetting.notification_email='email@email"
Can you also post the full rebuild output?
I’m pretty sure that the lines you see happen in every rebuild since forever and don’t block the rebuild in any way, since we are just ensuring redis is running in two different hooks. Your problem is elsewhere.
Sure. If you need any other logs, I can provide them :slight_smile:
I posted them on pastebin, because it’s over 3226 Lines and exceeds the Forum post limit: Pastebin.com - Potentially offensive content ahead!
That output shows a successful rebuild…
Isn’t your site working on port 12080 ?
Yes the the SIte is rebuilding again successful.
I found out the cause of the problem, why the site didnt load properly on me.
The fault was in a SSL Reverse Cert, which didnt autorenew and caused the site to not load the Images, which let me to assume, that the Redis Cache was not working :man_facepalming:
The Build shows the notice, but the Redis Server runs fine.
After renewing the SSL Cert, the site worked again.
Thanks for you support and sorry for my stupidity :sweat_smile:
