No "Publish to discourse" checkbox in post editor
WP Discourse plugin is successfully connected to Discourse forum: “You are connected to Discourse!”
However i cant seem to find the “publish to discourse” checkbox that used to be in the post editor.
I checked all options in “screen options” but there isnt anything related to Discourse.
Under “add custom field” i can see the discourse related fields.
I have both Wordpress and Discourse on https, if that means anything.
My wordpress is on a Easyengine setup.
Any ideas whats wrong and what i could do to debug and fix this?
What is the post-type that you are trying to publish? Is it selected under the ‘Post Types to publish to Discourse’ setting on the ‘Publishing Options’ page?
