The discussion revolves around a NoMethodError encountered when trying to run a Discourse Docker container on a new machine. pmayer initially faced issues after migrating the container, receiving an error in pups/config.rb. After attempting to fix the config.rb file without success, they resolved the issue by running ./launcher rebuild apppmayer. codinghorror advised using the web UI for backups instead of moving containers. tgxworld suggested the error might stem from a corrupted app.yml file, though pmayer confirmed they hadn’t modified it. Other users, including Muthukkumar and trying2survive, reported similar issues when deploying Discourse on different environments, such as DockerHub or AWS ECS. Dev_Work sought guidance on CLI backups, later finding a solution via the Discourse meta forum Dev_Work.
I must admit, that I’m not a docker guru… only doing baby steps. I’ve installed Discourse about a year ago for testing on a local server. But as you know, things for “testing” suddenly get addopted and used on a daily basis.
Discourse is used for our local makerspace and I wanted do move the docker Image to new machine. Discourse itself got updates via the administrator webinterface.
So I first stopped the containter with docker stop <container-id> and then wanted to export the docker image. Just to be sure to not have broken something, I’ve tried to “start” the docker image again:
pm@mandark:~ docker run local_discourse/app:latest
From https://github.com/SamSaffron/pups
2b8776d..7bde3d3 master -> origin/master
Updating 2b8776d..7bde3d3
Fast-forward
README.md | 2 +-
lib/pups/config.rb | 9 ++++++++-
2 files changed, 9 insertions(+), 2 deletions(-)
I, [2017-04-13T14:34:38.212099 #17] INFO -- : Loading --stdin
/pups/lib/pups/config.rb:23:in `initialize': undefined method `[]' for nil:NilClass (NoMethodError)
from /pups/lib/pups/cli.rb:27:in `new'
from /pups/lib/pups/cli.rb:27:in `run'
from /pups/bin/pups:8:in `<main>'
As the Image worked some minutes ago I’m not aware what to do now. Also I’m not sure if I used the launcher or not. When I try to launcher start web it will load a new discourse docker image from the web.
I’m using Ubuntu 16.04.2 LTS with Docker version 17.04.0-ce, build 4845c56.
I am having same issue while run the container image from different machine. My image is running in A machine then I have pushed the container image to dockerhub then pulled it to B machine.
When I try to run the image I am not able to run it. Could some one help me fix it.
Ho riscontrato anche questo errore durante il tentativo di distribuzione su AWS ECS. Ho già passato le variabili d’ambiente richieste da ./launcher start app. Il container funzionava correttamente sul mio server EC2 autonomo.
