خطأ NoMethodError في إضافة التصويت
/log السجل على النحو التالي
activemodel (8.0.5) lib/active_model/attribute_methods.rb:512:in 'ActiveModel::AttributeMethods#method_missing'
activerecord (8.0.5) lib/active_record/attribute_methods.rb:495:in 'ActiveRecord::AttributeMethods#method_missing'
/bitnami/discourse/plugins/poll/app/serializers/poll_serializer.rb:28:in 'PollSerializer#include_public?'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:375:in 'ActiveModel::Serializer#include?'
(eval at active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):7:in 'PollSerializer#_fast_attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in 'ActiveModel::Serializer#attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in 'ActiveModel::Serializer#_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in 'ActiveModel::Serializer#serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:347:in 'ActiveModel::Serializer#as_json'
activesupport (8.0.5) lib/active_support/json/encoding.rb:41:in 'Oj::Rails::Encoder#encode'
activesupport (8.0.5) lib/active_support/json/encoding.rb:41:in 'ActiveSupport::JSON.encode'
activesupport (8.0.5) lib/active_support/core_ext/object/json.rb:42:in 'ActiveSupport::ToJsonWithActiveSupportEncoder#to_json'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:331:in 'ActiveModel::Serializer#to_json'
multi_json (1.19.1) lib/multi_json/adapters/oj.rb:62:in 'Oj.dump'
multi_json (1.19.1) lib/multi_json/adapters/oj.rb:62:in 'MultiJson::Adapters::Oj#dump'
multi_json (1.19.1) lib/multi_json/adapter.rb:66:in 'MultiJson::Adapter.dump'
multi_json (1.19.1) lib/multi_json.rb:195:in 'MultiJson.dump'
app/controllers/application_controller.rb:526:in 'ApplicationController#render_json_dump'
app/controllers/topics_controller.rb:1475:in 'block (2 levels) in TopicsController#perform_show_response'
actionpack (8.0.5) lib/action_controller/metal/mime_responds.rb:224:in 'ActionController::MimeResponds#respond_to'
app/controllers/topics_controller.rb:1462:in 'TopicsController#perform_show_response'
app/controllers/topics_controller.rb:202:in 'TopicsController#show'
actionpack (8.0.5) lib/action_controller/metal/basic_implicit_render.rb:8:in 'ActionController::BasicImplicitRender#send_action'
actionpack (8.0.5) lib/abstract_controller/base.rb:215:in 'AbstractController::Base#process_action'
actionpack (8.0.5) lib/action_controller/metal/rendering.rb:193:in 'ActionController::Rendering#process_action'
actionpack (8.0.5) lib/abstract_controller/callbacks.rb:261:in 'block in AbstractController::Callbacks#process_action'
activesupport (8.0.5) lib/active_support/callbacks.rb:120:in 'block in ActiveSupport::Callbacks#run_callbacks'
app/controllers/application_controller.rb:447:in 'block in ApplicationController#with_resolved_locale'
i18n (1.14.8) lib/i18n.rb:354:in 'I18n::Base#with_locale'
app/controllers/application_controller.rb:447:in 'ApplicationController#with_resolved_locale'
activesupport (8.0.5) lib/active_support/callbacks.rb:129:in 'block in ActiveSupport::Callbacks#run_callbacks'
app/controllers/application_controller.rb:1098:in 'ApplicationController#ensure_dont_cache_page'
activesupport (8.0.5) lib/active_support/callbacks.rb:140:in 'ActiveSupport::Callbacks#run_callbacks'
actionpack (8.0.5) lib/abstract_controller/callbacks.rb:260:in 'AbstractController::Callbacks#process_action'
actionpack (8.0.5) lib/action_controller/metal/rescue.rb:27:in 'ActionController::Rescue#process_action'
actionpack (8.0.5) lib/action_controller/metal/instrumentation.rb:76:in 'block in ActionController::Instrumentation#process_action'
activesupport (8.0.5) lib/active_support/notifications.rb:210:in 'block in ActiveSupport::Notifications.instrument'
activesupport (8.0.5) lib/active_support/notifications/instrumenter.rb:58:in 'ActiveSupport::Notifications::Instrumenter#instrument'
activesupport (8.0.5) lib/active_support/notifications.rb:210:in 'ActiveSupport::Notifications.instrument'
actionpack (8.0.5) lib/action_controller/metal/instrumentation.rb:75:in 'ActionController::Instrumentation#process_action'
actionpack (8.0.5) lib/action_controller/metal/params_wrapper.rb:259:in 'ActionController::ParamsWrapper#process_action'
activerecord (8.0.5) lib/active_record/railties/controller_runtime.rb:39:in 'ActiveRecord::Railties::ControllerRuntime#process_action'
actionpack (8.0.5) lib/abstract_controller/base.rb:152:in 'AbstractController::Base#process'
actionview (8.0.5) lib/action_view/rendering.rb:40:in 'ActionView::Rendering#process'
rack-mini-profiler (4.0.1) lib/mini_profiler/profiling_methods.rb:90:in 'block in ActionController::Base#profile_method'
actionpack (8.0.5) lib/action_controller/metal.rb:252:in 'ActionController::Metal#dispatch'
actionpack (8.0.5) lib/action_controller/metal.rb:335:in 'ActionController::Metal.dispatch'
actionpack (8.0.5) lib/action_dispatch/routing/route_set.rb:67:in 'ActionDispatch::Routing::RouteSet::Dispatcher#dispatch'
actionpack (8.0.5) lib/action_dispatch/routing/route_set.rb:50:in 'ActionDispatch::Routing::RouteSet::Dispatcher#serve'
actionpack (8.0.5) lib/action_dispatch/journey/router.rb:53:in 'block in ActionDispatch::Journey::Router#serve'
actionpack (8.0.5) lib/action_dispatch/journey/router.rb:133:in 'block in ActionDispatch::Journey::Router#find_routes'
actionpack (8.0.5) lib/action_dispatch/journey/router.rb:126:in 'Array#each'
actionpack (8.0.5) lib/action_dispatch/journey/router.rb:126:in 'ActionDispatch::Journey::Router#find_routes'
actionpack (8.0.5) lib/action_dispatch/journey/router.rb:34:in 'ActionDispatch::Journey::Router#serve'
actionpack (8.0.5) lib/action_dispatch/routing/route_set.rb:908:in 'ActionDispatch::Routing::RouteSet#call'
lib/middleware/omniauth_bypass_middleware.rb:35:in 'Middleware::OmniauthBypassMiddleware#call'
lib/middleware/crawler_hooks.rb:11:in 'Middleware::CrawlerHooks#call'
rack (2.2.22) lib/rack/tempfile_reaper.rb:15:in 'Rack::TempfileReaper#call'
rack (2.2.22) lib/rack/conditional_get.rb:27:in 'Rack::ConditionalGet#call'
rack (2.2.22) lib/rack/head.rb:12:in 'Rack::Head#call'
actionpack (8.0.5) lib/action_dispatch/http/permissions_policy.rb:38:in 'ActionDispatch::PermissionsPolicy::Middleware#call'
lib/content_security_policy/middleware.rb:12:in 'ContentSecurityPolicy::Middleware#call'
lib/middleware/anonymous_cache.rb:420:in 'Middleware::AnonymousCache#call'
lib/middleware/csp_script_nonce_injector.rb:12:in 'Middleware::CspScriptNonceInjector#call'
config/initializers/008-rack-cors.rb:14:in 'Discourse::Cors#call'
rack (2.2.22) lib/rack/session/abstract/id.rb:266:in 'Rack::Session::Abstract::Persisted#context'
rack (2.2.22) lib/rack/session/abstract/id.rb:260:in 'Rack::Session::Abstract::Persisted#call'
actionpack (8.0.5) lib/action_dispatch/middleware/cookies.rb:706:in 'ActionDispatch::Cookies#call'
actionpack (8.0.5) lib/action_dispatch/middleware/callbacks.rb:31:in 'block in ActionDispatch::Callbacks#call'
activesupport (8.0.5) lib/active_support/callbacks.rb:100:in 'ActiveSupport::Callbacks#run_callbacks'
actionpack (8.0.5) lib/action_dispatch/middleware/callbacks.rb:30:in 'ActionDispatch::Callbacks#call'
actionpack (8.0.5) lib/action_dispatch/middleware/debug_exceptions.rb:31:in 'ActionDispatch::DebugExceptions#call'
actionpack (8.0.5) lib/action_dispatch/middleware/show_exceptions.rb:32:in 'ActionDispatch::ShowExceptions#call'
logster (2.20.1) lib/logster/middleware/reporter.rb:40:in 'Logster::Middleware::Reporter#call'
lib/middleware/default_headers.rb:13:in 'Middleware::DefaultHeaders#call'
railties (8.0.5) lib/rails/rack/logger.rb:41:in 'Rails::Rack::Logger#call_app'
railties (8.0.5) lib/rails/rack/logger.rb:29:in 'Rails::Rack::Logger#call'
config/initializers/100-quiet_logger.rb:20:in 'DiscourseRackQuietAssetsLogger#call'
config/initializers/100-silence_logger.rb:29:in 'Silenc
هل تقوم بتشغيل هذا على نسخة Bitnami؟ :thinking: أنا متأكد تمامًا من أن هذه الإصدارات قد تم إيقاف دعمها منذ فترة طويلة…
قررت البحث في هذا الأمر لأنني لم أسمع من قبل عن Bitnami، ويبدو أنهم ما زالوا ينشرون الإصدارات، لكنني لا أستطيع تخيل أن يعمل كما هو الحال مع التثبيت القياسي
أعتقد أن هذا هو السبب في وجود موضوع التوثيق القصير جدًا هذا:
قد يكون zogstrip يشير إلى Bitnami Discourse container image is deprecated
@Moin @zogstrip @darkpixlz الإصدار هو الأحدث
