Notification error
at this time, I have launcher rebuild app
now,
Notification error.
We are having the same problem with our language, English seems to work…
It seems that problem is with @eviltrout commit:
https://github.com/discourse/discourse/commit/b2ffaf93a300e23de2c8c5801bf982740bc785fa
Are there any errors in the logs? I did change the translations for notifications to remove hard coded HTML, but I’m not even seeing the text there.
I don’t know if these problems are even related but they both appeared after updating discourse today.
https://meta.discourse.org/t/xmlhttprequest-cannot-load-message-bus-due-to-access-control-checks-and-notifications-text-is-missing/70061
I don’t understand … what text you don’t see? You don’t see the same problem when you change from Englist to something else … Spain for example?
If it’s any help here’s rendered HTML for non-English:
and here for English:
I hadn’t tried it out yet – I was just looking for more data before checking out the branch again. I can reproduce it now and am looking for a fix that can last until things are translated properly.
4 лайка
I am now back off using the beta channel in containers/app.yml
:joy::joy:
Is it safe to downgrade?
Looks like there is no problem.
This should fix it up until the other languages are translated:
https://github.com/discourse/discourse/commit/38064c5776f9612a0c1a383950bbb7e5be3e9e4a
4 лайка
Could you point us to the right direction … which translations exacty are you talking about? I tried to search Transifex but can’t figure out what to search for :blush:
I’m not sure how often Transifex updates from master, but the keys that need to have the HTML removed are in this commit:
3 лайка
I think about once or twice a day…
