No, I don’t use anything like that. The phone is basically as it comes out of the box. It’s the latest OS, but it is an iPhone 4S, which might make some difference. The iPad is newer, and the notifications work fine there, so it could just be the device’s age, although it still seems a bit strange, as it works well otherwise.
Good question. I just logged in here on the phone and the same issue occurs. Clicking on the avatar, the dropdown appears, the loading icon appears for a split second, and then the notifications section closes up with no content in it.
O well, seems like it might be something loopy with my phone if others aren’t seeing it on an iPhone. Figured it was worth reporting, but sorry if it’s a wild goose chase.
I think (but am not absolutely certain, unfortunately) that the problem started with our recent update. I’m pretty sure this used to work. (I don’t visit a lot on the phone, but was away over the week end and only had the phone available for checking in.)
I don’t have an iPhone 4 here to test, but I tried with the simulator in 4s mode and it works fine. I tried here on meta, turtle rock and logged in / logged out. It always displays
