Onze site laadt plotseling niet meer
forum.iqolympiad.org
our site is currently using discourse 14day free plan.
I was using it well, but I can’t access it well on my desktop.
(can access it well on mobile)
The same goes for other users. Please help to fix
It is loading fine here,
I don’t know why admin users can’t load.
Cannot load in Chrome on mobile too
Not firefox, edge too.
Samsung interent app is fine.
Either your ISP or some kind of firewall on your network might be blocking connections to AWS it seems.
Thanks, what can I do fix it?
Do You have some kind of browser extension? E.g. adblocker or some kind of Javascript blocker?
I Don’t have a concrete solution other than trying a VPN if nothing else works.
Maybe contact Your ISP?
It also loads for me too, so I guess Bhanu’s suggestion is apt here.
You can try using a new/clean browser with no extensions installed and then try a different internet connection or ISP too. Also, try using your phone to load it, does it work for you?
Does it only fail once you log in? Does it work if you’re not logged in?
Have you tried safe mode? https://forum.iqolympiad.org/?safe_mode=no_custom%2Cno_plugins%2Conly_official
If none of that makes any difference, can you show the Network tab of devtools? Do all of the assets from the CDN fail?
