[Paid] Migration from IPB4 to Discourse
What would you like done?
Migrate the ScriptBrasil Forum (https://forum.scriptbrasil.com.br), from IPB v4.4.10 to Discourse. We already hosted the Discourse (v2.5.0.beta2) in a another server and copied the database and files from IPB (uploads/avatars/etc.).
All old URLs (categories/posts) should works fine. Can be rewrite rules.
This is a open and older tech community in Brazil. We looked at some IPB imports scripts, but it not worked with the latest version.
When do you need it done?
April 2020.
What is your budget, in $ USD that you can offer for this task?
$ 300.
I saw that this topic had been re-opened, so perhaps you’re still interested in getting this done?
If you know that the existing IPB scripts don’t work with your database, you know that it is probably 1-3 days work to solve your problem. It’s difficult for me to imagine that I’d do this job for less than 5-10X your budget (which I presume is why I didn’t reply when this was posted), but if you’d like to answer the questions at Migrate to Discourse Discussion Platform from your current formum software. we can start a conversation.
