Festinger
(Festinger )
August 29, 2023, 9:24am
1
What would you like done?
I would like to have some assistance to get my Discourse instance back online.
Hi,
I just rebuilt my Discourse server but I am getting a Failed Error to Bootstrap:
I, [2023-08-28T19:59:34.143282 #1] INFO -- : Terminating async processes
I, [2023-08-28T19:59:34.143377 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
2023-08-28 19:59:34.143 UTC [42] LOG: received fast shutdown request
I, [2023-08-28T19:59:34.1…
When do you need it done?
As soon as possible.
What is your budget, in $ USD that you can offer for this task?
Please let me know your price by PM if you’re interested. Thank you.
I can help with it, sending a DM.
This is related to Discourse Chatbot 🤖 (Now smarter than ChatGPT!*) - #382 by merefield
I suspect.
Apologies. A helpful exception message should have been printed. I’ll investigate why it wasn’t.
But follow those instructions or exclude chatbot and you should be back online.
merefield
(Robert)
September 1, 2023, 6:19am
5
I’ve updated the plugin so that a clear exception with link to guidance is printed in the case you haven’t installed the required postgres add-on.
This should now look like:
Text for the search engine:
----------------------------DISCOURSE CHATBOT ERROR----------------------------------
Discourse Chatbot now requires the embedding extension on the PostgreSQL database.
See required changes to `app.yml` described at:
https://github.com/merefield/discourse-chatbot/pull/33
Alternatively, you can remove Discourse Chatbot to rebuild.
system
(system)
Closed
October 1, 2023, 6:20am
6
