Parenthesis don’t do the superscript correctly
I noticed that the parenthesis don’t do the superscript correctly. For example,
$2^(ceil(ln(N)))$
displays it like this:
2^(ceil(ln(N)))
(ceil(ln(N))
Check your matching parens.
I get this even with matching parenthesis.
You are typing AsciiMath delimited by LaTeX delimiters. To use AsciiMath, try:
%2^(ceil(ln(N)))%
To get the same result in LaTeX, try:
$2^{\lceil \ln(N) \rceil}$
Thank you that worked.
