העבר מאפיין בתבנית מחבר
How can I use plugin api to pass property into the handlebar template?
I’m Trying to show different text depending on wether current topic is public. I’m using the topic-above-post-stream connector outlet.
I tried to extend the api.modifyClass(“component:topic-category”,{}) and set property in init() method, it shows in the console, but not actually showing in this
ah, figured out according to this: Adding a form to a plugin - #3 by Johani
had to use setupComponent()
