Los tokens de Patreon desaparecen del panel de administración
Estoy en la versión v1.9.0.beta2 +35 y hoy, mientras revisaba la configuración del sitio, descubrí que los tokens de Patreon desaparecieron.
Intenté ejecutar el trabajo en Sidekiq (sin tokens) y funciona.
IkBZL43
Todos los demás ajustes del sitio siguen igual, excepto por esto:
Esos botones siempre aparecen, incluso si el «modo de lista de correo» no está habilitado en mi foro.
EDITO: Había guardado todos los datos relacionados con Patreon en un documento en mi PC y puedo ver que los tokens son diferentes en comparación con los que encontré en Patreon hoy.
Así que no sé si se trata de algo relacionado con el complemento de Patreon o con el sitio de Patreon y sus cambios recientes.
There were some changes at Patreon recently. @falco should have a look.
I just tried to log I to a site that I maintain and the Patreon login page has the login button grayed out.
Edit: And on the browser where I’m still logged in, clicking the Patreon tab gives me a 500 error. Perhaps that’s due to problems with rubygems.
Do you have any entries on the log related to Patreon @Trash?
This site settings are very peculiar, because they are update every week for new tokens.
Maybe the process failed somehow and the credentials got wiped.
And I think you still have credentials for mine, @falco. I get a 501 when I access the plugin page.
I’ve got old errors (178)
 Job exception: undefined method map' for nil:NilClass
and the sync on Sidekiq for Patreon groups FAILED.
Now I have
  1. Update the client key on Patreon
  2. Insert the new tokens on Discourse
  3. Manually trigger the job on Sidekid (result OK)
No new errors in logs.
It seems that in this way all works again. I’ll check again sidekiq and logs in 5 hours to see if the next job automatically works without errors.
I can confirm that all is working now. The automatic job to sync groups on sidekiq runs and I have no error on logs.
:scream: So is it possible that next week I will have the same problems…
I will check the settings again next week
I added better error handling and logs around this:
https://github.com/discourse/discourse-patreon/commit/df4c1178ec5bf3458585053a037c88c7b41773f9
