קישורי קבוע כבר לא מאפשרים חיפוש או הצגת כל הקישורים הקבועים
סיכום מבוסס בינה מלאכותית
After upgrading to Discourse v3.4.0, atw noticed that the /admin/config/permalinks page no longer allows access to all permalinks, only showing 100 with no way to show more. pfaffman suggested using the search function or the data explorer plugin to find specific permalinks. However, atw pointed out that the search feature now only searches the initially loaded 100 permalinks. pfaffman and sam acknowledged this as a potential bug or oversight. Nevertheless, Jagster thought it might be by design, similar to the system settings listing system. The issue has been addressed and Osama confirmed that it will be fixed in https://github.com/discourse/discourse/pull/31354. atw thanked Osama for the update.
We have well over 100 permalinks in our Discourse instance and after recently upgrading to v3.4.0 the /admin/config/permalinks page no longer has a way to access all of the permalinks. It only shows 100 with no way to show more.
This was not a problem in v3.3.0 where the search would work for the entire list.
So this appears to be a regression in 3.4.0.
2 לייקים
I think that might be by design and that you need to search for the ones you’re looking for. I thought it was always like that, but maybe I’m wrong?
Another way to get them is to use the data explorer plugin.
Yeah it was always that way where you have to use Search to find them. The problem is that the Search feature doesn’t do that anymore, it only searches the 100 that are initially loaded in the UI.
That does sound like a bug!
Or they use same search/listing system than what system settings used and it gave only 100 hits too. So I don’t think it is actually a bug, but by design.
2 לייקים
This certainly sounds like an oversight, someone from the team will have a look!
5 לייקים
This will be fixed in:
Thanks for the report @atw :pray:
6 לייקים
Thanks @Osama :sparkler:
לייק 1
