我在哪里可以查看所有固定链接?
I migrated forum to discourse and now in admin->customize->permalink I see around 50 links. There is no way to browse other links. If I search for a specific link then it shows that link. Where can I see all links. I would like to know how many total links are redirected.
Thanks!
1 个赞
That’s a limitation of the interface. You can use the data explorer plugin to see them all.
3 个赞
Ok, thank you! Initially I thought it is the problem with import script.
2 个赞
