Hi there, I have about 80,000 permalinks, and the current UI at /admin/customize/permalinks only shows about ~100 of them. To be useful it would need an option to sort by the URL column and/or search for an exact value (i.e. node/70 , which currently shows node/70899 through node/70999).
You can do that with Data Explorer and a simple SQL query. ![]()
SELECT *
FROM permalinks
WHERE url LIKE '%node/70%'
