Plugin QUnit tests are not running as part of rake qunit:test
The issue is that running rake qunit:test in the Discourse docker development environment does not run QUnit tests for plugins, whereas it does when run natively on a Mac. This issue also occurs in the Discourse Travis build.
After investigation, david found that the issue is due to the LOAD_PLUGINS environment variable not being passed through to the container when using the bin/docker/rake script.
To fix this, david suggested setting the LOAD_PLUGINS variable in the Dockerfile or running docker run -e "LOAD_PLUGINS=1" -it --rm discourse/discourse_test. A PR was made to turn on plugin QUnit tests on Travis, which revealed legitimate test failures in several plugins.
david is seeking feedback from sam on whether to load plugins for the tests-passed pipeline, as this could help catch broken core plugin tests. sam plans to investigate this further and integrate it into the CI pipeline.
It is my understanding that running rake qunit:test should run all of the qunit tests in Discourse, including those for any installed plugins. However, when I run the task in the docker development environment it only runs the core discourse tests (1980 of them).
When I run exactly the same command using my native mac development environment, it picks up the tests for the plugins (e.g. the ‘poll’ plugin), which results in more than 1980 tests, and I have no idea what’s causing this difference.
This exact same problem seems to occur in the Discourse Travis build - looking at this recent log, it shows
Time: 151618ms, Total: 1980, Passed: 1980, Failed: 0
So it’s not running the qunit tests for all the core plugins, even though it’s running their rspec tests.
I’ve tried investigating further but don’t really know where to look. I’m guessing there must be some kind of regex/filter which locates all the qunit test files?
RSpec tests are working fine, it’s the QUnit ones that aren’t working. I’ve tried putting LOAD_PLUGINS=1 before the rake command, but no luck :frowning:
I don’t think it’s a typo, since it’s an issue on Discourse’s own travis builds.
It sounds like something that we might have disabled due to random test failures which are unfortunately more common on travis than I’d like. If we can figure out how to run them again I’d be happy to reintroduce them!
That makes sense, but I can’t see any logic that disables/enables them… running rake qunit:test on my mac runs the plugin tests, running it in docker doesn’t…
I’ve been doing a lot of experimenting with QUnit today, and have had another look at this issue.
discourse_dev
The issue was indeed with the LOAD_PLUGINS environment variable. When using the bin/docker/rake script, the LOAD_PLUGINS variable doesn’t get passed through to the container, hence why I couldn’t get it working with the discourse_dev image.
discourse_test
I also experimented with the discourse_test image. It is my understanding that the discourse_test image is used to test master before merging into tests-passed (according to this). In its default configuration:
docker run -it --rm discourse/discourse_test
it does not seem to run any plugin tests at all (either rspec or qunit). I am assuming that’s how broken core plugin tests managed to end up in tests-passed. I managed to get it to run both qunit and rspec plugin tests by running
Maybe that’s something that could be used internally to make sure core plugins get tested properly? Or alternatively the LOAD_PLUGINS variable could be set in the Dockerfile?
Travis
Travis is currently running plugin rspec tests, but not qunit tests. I made a PR for turning on plugin qunit tests here:
https://github.com/discourse/discourse/pull/4971
Running that currently results in 11 qunit failures from a number of plugins: (Cakeday, Canned Replies, Details, and Spoiler)
QUnit Fails
Module Failed: Acceptance: Cakeday
  Test Failed: Anniversary emoji
    Assertion Failed: Error: Unhandled request in test environment: /t/11.json?track_visit=true&forceLoad=true&_=1499806929081 (GET)
      Expected: true, Actual: false
    Assertion Failed: TypeError: undefined is not an object (evaluating '$posterIcons[0].title')
  Test Failed: User is not logged in
    Assertion Failed:
  phantomjs://webpage.evaluate():49
Module Failed: Acceptance: Canned Replies
  Test Failed: Inserting canned replies
    Assertion Failed: Error: Unhandled request in test environment: /canned_replies?_=1499806929085 (GET)
    Assertion Failed: ReferenceError: Can't find variable: equal
  Test Failed: Editing a canned reply
    Assertion Failed: Error: Unhandled request in test environment: /canned_replies?_=1499806929088 (GET)
    Assertion Failed: Error: Element .reply-selector #canned-replies-combobox not found.
  Test Failed: Creating a new canned reply
    Assertion Failed: Error: Unhandled request in test environment: /canned_replies?_=1499806929091 (GET)
Module Failed: Acceptance: Details Button
  Test Failed: details button
    Assertion Failed: it should contain the right output
      Expected: Before
[details=Summary]
some text in between
[/details]
After, Actual: Before
[details=Summary]
[/details]
 After
Module Failed: Acceptance: Spoiler Button
  Test Failed: spoiler button
    Assertion Failed: ReferenceError: Can't find variable: ok
These are legitimate fails, which I can reproduce running the tests suite locally. I’ve already fixed all but one of the “discourse-details” tests, and the “Spoiler” test should be an easy fix. The others may need more investigation.
Edit: discourse-details PR here and spoiler alert PR here
@sam (I think discourse_test is your creation?), what do you think about loading plugins for the tests-passed pipeline?
The plugin qunit tests are now all fixed, but today many core plugin rspec tests were broken by the removal of the old markdown engine, yet the commit still ended up in tests-passed. (fails are in poll, discourse-details and discourse-narrative-bot).
I will have a look at this today… honestly I do not think the community can help out too much here, we have to plug this stuff in to our CI pipeline (we don’t really trust travis cause it is flaky and slow)… having a look at it later today.
