What would you like done?
I wanna Sync a Category evernote to category Discourse
When do you need it done?
Now!
What is your budget, in $ USD that you can offer for this task?
My available: 200$
Now!
My available: 200$
You should in theory be able to use something like Zapier - have it trigger when a new note is added and then have it create a new topic in Discourse both of which using the APIs that are available.
Take a search for using zapier on here - is pretty straight forward to set up.
Hey Sora! Sorry for the delay here. I saw your post on the theme topic as well.
I’ve played around with the idea of an importer for Discourse that uses Evernote as the source. But that wouldn’t provide a sync mechanism. That’s a LOT more involved. We can likely pull it off, but just a forewarning, the budget for this would need to be significantly higher than your proposed. There’s a lot of error checks and validations as well as data storage that needs to happen to do this well.
If you’d like to pursue it, you can email me here hello@procourse.co.
