Hello, I am not able to view the plugins section on my dashboard. I have restarted the forum to rebuild the plugins but the error has occurred again. Any help would be appreciated. Please see the image below.
The user charles_mabwa1 reports that the plugins section is not visible on their dashboard, even after restarting the forum. Stephen asks if the issue persists in safe mode, which charles_mabwa1 confirms. yhh9xdq7dc suggests the problem might be due to improperly set routes in a custom plugin, which could explain the missing plugins page. JammyDodger adds that similar issues have occurred with the adplugin when an ad blocker is enabled, recommending trying an incognito browser. charles_mabwa1 confirms that using an incognito browser resolved the issue.
Does the same thing happen in safe mode?
It also happened to me with a plugin I created when I didn’t set the routes for the plugin settings page well. Then once fixed it worked fine and I was still seeing the plugins page.
Hi @Stephen yes it does.
Thanks for this reply, perhaps I can try this
FWIW There have been a few instances of this happening with the adplugin and having an adblocker enabled. If you have the adplugin it might be worth trying in an incognito browser?
This worked for me. Thanks @JammyDodger
