After the update to 3.5.0.beta4-dev the menu item for polls is not there anymore.
Also all existing polls do not work.
Any idea how i can fix this?
Do the polls work if you test in safe mode?
No, same behaviour in safe mode:
PS: Why is my original question with the picture not visible any more?
Just as an FYI, polls are a core plugin so safe mode with plugins disabled would actually turn them off (but there is an option to just disable themes as part of the safe mode options, which can still be very helpful).
Just to rule it out, is your Poll enabled
admin setting toggled on?
If so, are there any errors in your browser console or /logs
page that could provide any clues?
Ah, looks like an issue with the experimental auto-translate feature that’s currently being worked on here on meta. If I turn off the translation (using the button by the timeline) then I can see your original post.
Yes.
Nothing obvious. But we are analysing some of them now. I will come back to this thread with details.
Hopefully you’ve got it all smoothed out, but if not maybe you could share a link to your site (the one in your profile doesn’t seem to work for me) and we may be able have a peek and see if we can spot something.
That´s strange. https://das-gruene-forum.de is the correct link?
That one works for me.
Having a little scout around as anon I found this topic with an old poll in Wer hat schon von ETS2 gehört? Und was hat das mit dem Heizungsgesetz zu tun? - #2 von WitzelJo - Gegenmaßnahmen - Forum für Grüne Politik, and it’s showing up as normal for me:
Our Provider did a rebuild this afternoon (CET+1) and that solved the problem. Was probably caused by a failed update? Maybe wrong order of updates?
But thanks for looking!
No worries. A rebuild can often sprinkle a bit of magic on things. Glad it’s sorted.
