this is my first post here, I hope I am doing everything right.
Is it possible to change the joined date for any given user?
I ask, because I want to bootstrap my forum and make it ready for launch day, but I want the first user (admin and system) to be joined on launch day and not before. Any idea how I could achieve that if I can not change the joined date?
I could delete my admin account on launch day an register a new one. Is that possible with the user @system ?
Thanks guys, the software is really easy and fast to install. I love it so far!
Only from SQL at the Ruby command prompt. Not in the UI at this time. But changing it via a DB query should be straightforward, there are some howtos here on that.
Yeah good point I did some searching but nothing good came up immediately. We should have a dedicated howto topic for entering the container, and running an arbitrary SQL query. @techapj can you assist?
It’s kind of like this
But more generic. That’s basically impossible to find if you want to just “run a query” against your Discourse database.
If me and @system are the only two users in the forum I can run a query to change the joined date for all users, as mentioned in the topic you linked. But I’ve no idea how that query should look like. I will wait for @techapj, hopefully he can help me with that.
I did some manual join date modification for some of the oldest users on a forum when I migrated. Like Jeff suggested, you basically need to pick out the users manually, like so:
user = User.find_by(username: 'krilnon')
user.created_at = Time.now
# user.created_at = Time.parse('2013-02-04 3:00 PM') # to backdate
user.save!
