Mogelijk om alle onderwerpen van opgegeven ID's te dempen?
in personal setting, could ignore/mute posts from ignored IDs, but the placeholders are still there.
possible to totally mute topics/posts from ignored IDs ?
at the bottom of a topic, could mute this topic, but only for this one topic, possible to add a preference setting, to allow mute all topics from specified IDs ?
sounds like you are using mute instead of ignore. go to user preferences - users tab and add users to the ignore function instead of mute. their posts will be replaced by an “ignored content” comment.
thanks for your reply, @Lilly
I tried both mute and ignore in preference setting
I could see the comments/posts being hidden for the specified ID.
but my question is how to hide the topic from the topic list page for a given ID.
say on this list page: Support - Discourse Meta
how to totally hide the topics/discussion thread started by a given ID.
some users on our site, they want to be able to do that…
very likely, it is not supported yet. but seems there is some use case/need for this…
thanks…
I just wrote a theme component for you
nice work @Lhc_fl ! :clap:t2: :slight_smile:
thanks, @Lhc_fl will try !
