Post.where() causing 500 error
Noooob question (2 days ruby experience :wink:
I have a plugin almost doing what I want but have a hang up here:
 posts = Post.where('user_id = ? and post_number = ?', params["uid"], params["tid"])
		      .order(created_at: :desc)
		      .limit(params["total"])
I’ve tried a number of versions. but they all case errors .
It feels more like a query issues than syntax but I bow before the experts edu-mecate me.
What does the logs say? :slight_smile:
so good of you to ask, and admittedly that helped… :smiley:
BUT perhaps you can assist further with my query! The issue was the input value
while I can do
ok
Post.where('user_id: '1,2') #works
Post.where('topic_id: '4,5')  #works
Fails
Post.where('user_id = ? or topic_id = ?', '1,2', '4, 5') #fails!
So again I assume! I’ll need to iterate over each user id, but… NOOOOB (assistance greatly appreciated!
So why did it fail? What is the error that was raised when you ran the code? :slight_smile:
Boom! (thanks BTW )
ActiveRecord::StatementInvalid (PG::InvalidTextRepresentation: ERROR:  invalid input syntax for integer: "1,2"
LINE 1: ...ERE ("posts"."deleted_at" IS NULL) AND (user_id = '1,2' or t...
: SELECT  "posts".* FROM "posts" WHERE ("posts"."deleted_at" IS NULL) AND (user_id = '1,2' or topic_id = '4')  ORDER BY "posts"."created_at" DESC LIMIT 30)
/var/lib/gems/2.2.0/gems/rack-mini-profiler-0.9.9.2/lib/patches/db/pg.rb:93:in `exec'
Try Post.where(user_id IN (?) OR topic_id IN (?), [1,2], [4,5])
So if I say post.where() it causes a error?
@tgxworld Thanks that helped a bunch.
For the record I was doing a bunch of stuff that I SHOULD have known better…
  1. not splitting the string to an actual array (duh facepalm )
  2. your request seems to have fix the syntax issues (woot)
final code
uid = params["uid"].split(",")
tid =  params["tid"].split(",")
posts = Post.where('user_id IN (?) OR topic_id IN (?)', uid, tid )
			.offset(params["start"])
obj = {follow_posts: posts }
render json: obj
Massive thanks!! :smiley:
This topic was automatically closed after 2 days. New replies are no longer allowed.
