פוסטים נוצרים כהערות HTML כברירת מחדל?
An instance of Discourse I admin has had a complaint that multiple posts are being posted by default as HTML comments such as:
This is the actual content of a post.
However, there are no special plugins enabled other than the retort plugin and the discourse-solved plugin which could do this.
We’re on the latest update as of today, has anyone ever seen this happen on a dockerized instance?
Do these lines start with 4 spaces? Can you link to a post?
Nope, I figured out the problem. The core problem was some categories have a template created with an HTML comment block in them.
And the users are not told to post outside the comment block, and simply remove the “Please read the guidelines” content between the comment lines and write their ipost in there.
So it’s entirely a combination of User Error and Staff Doing A Stupid
That is a powerful combo :rofl:
